ISO 06-09 V8 Limited 4wd
bebop
Member
Cross posted to other forums. Looking for a clean 4th gen in preferably driftwood pearl or metallic grey. Under 150k miles unless thoroughly documented maintenance. Zero rust is a must! Closer to stock the better.
Not sure if this forum is still active but hopefully someone is willing.
You will probably be looking for a long time.
I have a Silver 2006 4Runner SR5 with 144k miles. Surface rust but has been woolwaxed for years. Service history at the dealership from the original owner is immaculate also.
Remote start, 2 sets of keys, bluetooth added to factory headunit, charging port added in switch blank, no holes in frame, gibson catback exhaust, secondary air pump bypass, Eibach lift kit with 33s KO2, Timing and water pump done at 116K.
I recently installed new plugs, brakes/rotors, rear sway bar link and shocks. Very well taken care of little truck.
erinobr2000
