Issues after lift
sf jakey
I just installed Dobinsons 300 front and 599 rear springs with my Bilstein 5100 set on first clip up front. I got 2” front and 1” rear lift. Ride is noticeably improved, as is stance.
After doing the fronts, I now have the ATRAC light lit up and I have the crawl control flashing. I know I stretched the driver side ABS wire a bit, so I bought a replacement and installed it. Made no difference after starting back up. I plugged in my Carista and get a code of C1290.
I followed the instructions here to try the zero point calibration, and no luck with that either.
Any ideas?
Is there an actual code reader I should buy to fix the problem? I’d rather not go to dealer unless it’s the only choice.
Fixed it. The OBD port is upside down as you look at it. The number 4 and 12 ports are from the right hand side. All cleared.
perarenato
