Thanks, I’m so happy with how the bumper turned out.
There’s a section in the EWD called “Back-up Light”. The wiring is pretty simple:
From the wires that used to plug into your park/neutral position connector, the hot wire (black with a yellow stripe, fed into position 4 on the park/neutral position connector) and the reverse indicator wire (red with a yellow stripe, fed into position 8 on the park/neutral position connector) now are fed into the back up light switch connector (located on the passenger side of manual transmission).
When the reverse rail in the manual transmission engages with the switch, the circuit will close and light up your reverse lights. Easy as that!
I still haven’t gotten my cruise control wired properly (my clutch release switch). When I tried wiring it originally, I cut the wires that fed into the park/neutral position connector (the black wire with a yellow stripe and the white wire with a red stripe, wires 4 and 9 respectively) routed them through the interior, ran them under the dash and over to the clutch release switch. It hasn’t worked (even after jumping the wires together, it doesn’t work). I don’t think my wiring is wrong, I’m guessing the wires are too long resulting in too high of a resistance on the circuit, but that’s just a guess. I plan to tap into another hot wire from under the dash and connect it to the white/red wire and see if that solves the problem, I’m just lazy and haven’t gotten around to doing it yet. But if you know what my problem is I’m all ears.
