junkyard rear bump stops
Fyi so you don't have to carry a bunch of tools in, the bolt holding these bumps on is a 1/2". You will need a 5" extension to get in there.
Fyi so you don't have to carry a bunch of tools in, the bolt holding these bumps on is a 1/2". You will need a 5" extension to get in there. Also another note, buddy of mine said he had an 02 blazer parts vehicle. Went over to check out out, turns out it was a trailblazer and these do not have the same bumps. Pretty sure they are about the same length but they are smaller around and more conical. They might have worked but I didn't want to be the test case on them. Anyone using these unmodified, do they still catch your axle housing reliably with the rounded bottom? I noticed the blazer has a cup on the axle these fit into while with the 4 runner they are meant to catch onto the axle itself. I wonder if I might want to make a slight rounded cut into them if I leave them full length. I'm going to use them on a 8 wrap LC coil with 96-97 LC shocks swap so I should have around 4" of lift so I'm thinking I will not want to cut off the first ring.
REE
