Just installed lift, few questions...
10ac
Just installed bilstein 5100 lift, few questions about my lean ...
I have a 2014 t4r TE. I installed 5100's all around. Fronts are set at lowest setting clip with toytec eibach 521600 coil springs. The front driverside is lower than passenger. Is this normal and i need a top plate spacer to correct this lean?
Also the rear is same issue. There is a 1" lean on driverside. I do have nearly a full tank of gas.
If i need a top plate spacer on driverside front, will the toytec 1/4" do the trick? Is that what most of u guys need to fix the lean issue?
Folks have made mention of this on here... What the hell is the deal with that?
My tacoma had same issue as well as my 3rd gen runner. Weird thing is my numbers i measured before install wasnt even leaning that much, now its worse. Wonder if the stocks has a stiffer coil on the driverside to help with the lean.
I've never heard of such a thing! You should probably go back to the dealer and see if it's a factory defect. Did you measure the differences before you lifted it? was it leaning before or only after the lift?
J/K... enjoy
http://www.toyota-4runner.org/gsear....org/toyota-4runner-forum/&ss=4157j1237403j26
So what i have is just enough of thread left on the coilover mounting top studs to accomidate 1/4" spacer but anymore than that thick will need to be disassembled to add longer studs which will suck! Hoping the 1/4" top plate spacer will be close enough to help make it look right. Hate this has a lean!!
As far as rear, i used a daystar poly spacer that was 1 1/2" then had my work machinist cut them down to 1 1/8" thick so i wouldnt have too much rake. Im thinking ill shave it down more to help with the rear lean.
For the record, this is not Toyota specific, my last non-Toyota SUV had a similar lean. I stopped paying attention years ago...
Measurements
Before lift near full tank:
Front left- 34 5/8 Right- 34 7/8
Rear left- 36 3/8 Right- 36 3/4
After lift near full tank:
Front left- 36 3/8 Right- 37
Rear left- 37 1/2 Right- 38 1/2
goddesszilla
