Just lifted my 04 t4R!!!!!!!
Duc Hunter
Ah, now this is how they should have come from the factory. I will post more pics when the weather clears up and I can bath her. I use the Nitrous Enterprises lift kit (4inch front, 3.5 inch rear to maintain a little of the stock rake). My girlfriend had ordered it before all the dust got kicked up around NE and I was conversing with Tracy about it before she left NE. I talked to Anthony and he simply said if I was unhappy in anyway he would give me my money back, no questions asked. He also volunteered to come help me install it. I decided I could give him a chance and he was nothing but nice to me.
Now that the disclosure is out of the way. The install was easy, thanks to whitney8 for the recommendation to use a Pitman Arm Puller instead of a sledge hammer. The install took about 4 hours and only one snag was hit. The ride is wonderful, esp considering I have not had it aligned yet. The other advise I have is when doing the front end removing both sides of the ft sway bar allows it to swing out of the way easily. On the rear we used my stock jack between the rear axle and the frame to get enough separation to make the rear spring install easy.
What was the one snag? When we tried to remove my left rear shock the metal collar that is inside the lower shock bushing was frozen to the axle. When I twisted the shock the bushing moved. I tried pounding of off and I just burst the rear shock. The answer was a large Pitman Arm pulled. I was shocked that it was so tough, so my advise to everyone is pull the lower shock off the mount and grease it! I did on my new ones.
Here are a few pics.
This is the front bushing, now are they perfectly clean and shiny and painted, no. They are VERY strong! YES! I was stunned at how hard the plastic is, impressive stuff. Also those bolts are Grade 5, as provided by Anthony.
Before
After
I must say my experience with NE has been a very good one. Anthony was very nice and generous with his time. The product is very nice as well.
Now I need new tires! The journey never ends. I am going with BFG AT’s, they are great tires that I have experience with. The Revo’s/Michelins seem to be great too, just not quite aggressive looking for me. 95% of my driving is on the street. I will probably get 265/70.17’s since I want to maintain a full size spare under the bed, I do not want to cut very much if anything and I am not sure I want to get new wheels. I believe I need to get new wheels if I want to run 285’s. I may try them if I can find a shop who will mount on for a test fit. Thanks to everyone here for all the great info posted on this site. It was invaluable to me on this little endeavor.
Nice dude!! You're right when you say that they should come like that from the factory. Its a shame that Toyota made the 4th gen more "Suburban".
Definitely go with the 70 profiles tires, it'll help fill out the wheel wells.
when did he say this statement???
anyway, looks good. bigger tires a must :)
ScottAW said:
How does lifting it that much effect handling? Cornering?
To be honest it does not. It rides slightly stiffer but it taller. I am a "nice ride Nazi" and would have been mad if it handled like crap or if it was too stiff. It is neither. I love it.
As for the 70 series tires, I cannot decide between 185's and 265/70's/ I think I will decide when I see how much cutting I need to do with the 285's.
If you went with a 4-inch front lift and a 3.5-inch rear lift, then why does your 4Runner look like it's squatting in the rear?
Look at the running board in the 3rd picture.... it appears that the front edge is at least 2 or 3 inches higher than the rear edge. Well, at least the wheels wells appear even now.
You definitely need bigger tires now because the stockers look kinda silly.:eek:
I hate to sound negative, but I don't like the way it looks at all..... but maybe some big old mud tires would fix it right up, if you're into that sort of thing;):
I think part of the reason it looks like it is sitting on it butt is that it is on an uphill. I assure you the tail is still slightly higer than the nose. Yeah, it does need bigger tires now for sure.
I went with NE over RevTek because I wanted a little more lift than RevTek. Some people had problems with NE but I had none and am very happy with the kit and their service. RevTek is great also, as it Daystar.
Space saver spare, hehehehee, yeah I was trying to save weight and get better gas mileage and lower et's at the strip!
The reason the boards appear to sag in the rear is that they're level on a stock T4R, and the rear wheel wells are larger. When you even out the wheel wells with a 3" & 2.5" lift, the running boards are no longer parallel to the ground.
Personally, I would prefer an even 2.5" & 2.5" or 3" & 3" lift, because I think the truck looks nice with larger wheel wells in the back. I guess it's a matter of personal preference.
Glad you enjoy your lift. Drive around a little bit adn then retorque the front end bolts before you have your alignment done. That will ensure you everything is nicely settled.
Get bigger tires :D 265/70/17 is good as it wont affect your gearing much. But it might still look a bit small. Also before you get tires check your spare area for space. you have the 04 V8 with the full tow receiver, which limits space, make sur you have space for a proper spare before you buy.
You arevery lucky you dont have XREAS, otherwise you would be crying right now after busting a shock. And it make the install easier, not having XREAS. You should have read my write up on the lift install, at least that way you would have the pullers before hand ;)
Time to go wheeling now :D
Also, mine did settle a little in the first two weeks, particularly after I got out and flexed it a little. Then I had the front end alignment done.
After all the stuff thats been said about NE, you still went with them. I'm impress, I wouldn't trust my runner to a second hand shop like that.
Keep an eye on your cv angles. 3" is kinda the edge. Not to mention your alignment will be quite off without new UCA's.
