Brandonium
Member
So the entire hydraulic box comes off too? I will take pics of the process tomorrow.
Awesome, we are excited to see pics!
As for the install, yes an extra person and jack stands are helpful for sure. You will need to remove all of the hardware holding the KDSS lines and hydraulic box to the side of the frame so that they can be pulled away from the frame far enough for the sliders mounting plate to slide in between the lines and the frame. Then all of the lines get bolted back into their original positions.
Also you will need to take the bolts out of the fuel tank skid plate and let the skid hang down so that the lower rock slider mounting plate can slide in between the bottom of the frame and the skid plate.
We recommend starting with the bolts at the very top of the rock slider mounting plate first. Lift up on the outside of the slider to tip it up towards the vehicle a bit and then install the top bolts loosely. Then pull the slider down tight against the frame and install the remaining bolts on the side of the frame rail. Install the bolts along the bottom of the frame last.
Once all of the bolts are installed loosely, then you can tighten all of them down.
