just raised mine with OME
Seems like I keep getting conflicting information, I thought you told Jenn some female in the office took your order? Guess that doesn't really matter at this point, we will work something out with this. We don't normally sell used parts and shipping coils is not cheap due to the weight, that is why they offered a set at half price. The decision is not mine I am not the boss!
Let us know what you decide you want to do, if you want to swap out the coils or lift the front more. Leaving it like it is now isn't going to hurt anything on the vehicle either.
The spacers do not change the ride they are just a small plate that goes on top of the coil/shock assembly, they do not wear out they are made of aircraft aluminum.
I will not be in the office tomorrow but I will update everyone there. You can also email [email protected] if you have questions or if you decide what you want to do. We only check the forum messages once a day normally so faster replies would be through email, we have people checking those all day long.
if the spacers go on top of the assembly and you guys had assembled them at toytec does that mean my mechanic is going to have to unassemble the coil shock assembly or does this just bolt on top of that??
If you bought OME then there was no way they were assembled at Toytec. only the Toytec coilovers with Bilstein shocks are preassembled.
now, you can buy the toytec ones unassembled like I did, but you cant get the OME coilovers assembled
I got my OMEs pre assembled by toytec. It cost $50 each but it was worth it to me because a few years ago I compressed the coils myself when I installed my old Daystar lift and it was sketchy to say the least. I think mostly due to the fact the compressors I used came from Harbor Freight.
I apologize, I did not know that you could have Toytec assemble OME struts...
:hatsoff:
The top plate does require longer bolts for installation, so yes, they would need to be reassembled.
masson74, I would just leave the 890's in the rear, and leave the front completely alone. Don't put any spacers on it. The very little bit of rake you have right now does not look bad at all, in fact I think it looks better with a little rake personally. If you put spacers up front to "level it off", whenever you put a 100lbs of stuff in the back of your Runner, it'll be sagging in the back....which looks horrible.
My 2 cents: Leave it alone, it looks beautiful and works great as is.
Wow this ticks me off even more. So I paid an extra $100 for you guys to assemble the front shocks and coils and now I am going to have to pay the mechanic even more to disassemble and reassemble them!!!! When will this end.
Jenn told me it would be easier to put on the front spacers. Now it is sounding like it would have been cheaper to put on the 906 rear coils.
Wish I could get a straight answer.
If my mechanic does have to reassemble the front shocks and coils then TOYTEC should atleast refund me the $100 assembly charge!!!
Come on guys MAKE IT RIGHT ALREADY!!!!!
Dave
Ditto on that...
and if they already sent the spacers for half price, sell them to someone online for 3/4 price or something...
No I actually paid FULL price for the spacers and I really dont like the 1 inch rake!
Im gonna be straight up with you... you just bought new coils and they havent settled yet, in a few months you wont even notice it...
If you spend the money to have a mechanic put in the top plate, you are gonna have 1" rake the other way in a few months...
its that simple... everyone has rake, most trucks and Suvs are standard with rake one way or another.
2nd: a 3" lift is not gonna make your tires look any smaller than a 2" lift, 1" is not enough of a change to notice, unless you look for something to complain about.
i can guarantee you that the 906's will end up sagging so if you put those in and it will end up with a reverse rake. its only a 1 inch difference now so i really don't see the problem. if you ever load up your 4runner with anything, these springs will be much less likely to bottom out on the bumpstops. not to sound like an ahole but stop whining and live with it. the springs you have now will settle too and it will probably end up at the same height.
sorry guys wasnt trying to be a whining thread. I was just a bit frustrated. I guess I will wait a few months for the settling thing and hold on to the spacers just in case! Im just BIG on customer service I guess
Their (Toytec's) customer service is nothing to write home about - I certainly won't be buying from them again.
Darrick is the only reasonable guy to deal with over there - Doug is an absolute ass on the phone. Very confrontational.
In any case, when I had issues with my coils peeling I contacted Toytec and was hoping to get a replacement in a stiffer rating. After trying to explain my exact set up (Shrockworks plate bumper, 10,000lb winch, sliders and no front sway-bar contributing to front end weight and body roll) it was impossible to convince Doug that a 700# coil was a better option than the #600 provided. I insisted on having 700# coils sent out which was the best option - I came to this conclusion by sifting through threads on TTORA and finding people running similar setups.
Long story short - coils peeled after 1 winter (bad), I was able to get replacement coils (good), it was a pain in the ass getting the right coils (bad), first representative I talked too was ignorant and confrontational (bad), had to install the coils on my own (bad).
All in all, nothing special and I certainly wasn't impressed.
Wait... stop a minute... listen to what you just said... you had issues with a 10k lb winch and no front sway bar and 600# coils is what you ordered initially?? or is did you order 700# coils?
what you ordered initially and what you get is key. first of all, I have heard no company tell you to remove the front sway bar. OF COURSE you are gonna get body roll. but you know that, thats why you took it off!
and seriously, with a 10k winch? you think that the 600 vs. 700 rated coils are gonna make much difference?? put on your swaybar!! that will help!
cmon... You aren't seriously gonna complain in those circumstances??
the way it sounds, you didnt complain til after you realized you made a bad decision in ordering the lighter weight coils..
isnt that right?? you said they didnt peel for a whole winter! cmon, dont try and bullshit a bullshitter
Wait... stop a minute... listen to what you just said... you had issues with a 10k lb winch and no front sway bar and 600# coils is what you ordered initially?? or is did you order 700# coils? 600# coils were supplied by Toytec stating that they would be able to hold up the weight without a lot of preload. They were not able too - Toytec could not comprehend the situation and said that 600# was more than enough. They were wrong - if you are loading up the front end, go with a heavier coil so you can avoid preload and still have the shock body being the limiting travel factor as opposed to your newly compressed coil.
what you ordered initially and what you get is key. first of all, I have heard no company tell you to remove the front sway bar. OF COURSE you are gonna get body roll. but you know that, thats why you took it off! Who the hell would take off a sway-bar to get more body roll? That's just stupid... (perhaps for arcticulation?) I don't have to justify my decision to remove the sway bar, I was certainly not the first.
and seriously, with a 10k winch? you think that the 600 vs. 700 rated coils are gonna make much difference?? put on your swaybar!! that will help! Once again, I drove the truck with different coils - it made a HUGE difference. But hey, what do I know.
the way it sounds, you didnt complain til after you realized you made a bad decision in ordering the lighter weight coils.. The stock shocks they sent me are set up with the #600 coil and Toytec stated they would be suitable for my application after explaining what was going on the truck. Not knowing I would have to increase pre-load to the top of the collar just to keep the truck level. Toytec will probably fight you if you ask for 700# coils as they don't think they are justifiable on a Tacoma (they are made for their Tundra lift)
Good on ya for trying to defend Toytec, they don't deserve your loyalty.
Im sorry you saw this as "Insulting your intelligence" I was asking alot of questions for things you said that sounded vague...
I still have no idea what shocks you were mixing with these coils,what the other coils were etc.
from the info you gave us here, I have no reason to fault Toytec, Now, the latest post that you put up just today helps me understand a bit more where you are coming from.
and I tend to give people/businesses etc benefit of the doubt several times. The success stories from Toytec here and other boards are numerous, the people that arent so happy are few. I dont work for Toytec, and have no hard defined loyalties to them. I do however, have a problem with people being judged unfairly (based on the info you gave, I felt that was the case) and that may have been the reason I jumped in to defend them.
to each their own. :peace:
workingwheelswnc
