JWaldz '99 Adventure Build - Dual Locked | Geared | Mid-Travel | 35s | Armored
Good stuff. Im interested in something I saw on expedition portal. Making a swing down skid/ roto pax mount for the spare tire location to keep the cans out of the way. Maybe I can figure something out for my own application.
That would be interesting.. Got a link?
Diagnosed some steering wobble I been getting lately and upon further inspection looks like my steering rack is bout to go out. At first when I jacked up the truck and tested for side to side play I thought it was the inner tie rod. I had JUST replaced it not long ago though. So, I took the boot off and shook it side to side again. I could see the whole inner shaft of the steering rack moving around A LOT. lol I'm guessing this is not normal?! I've also been hearing some popping noises up front which I can only assume are related considering both lbj's and all tie rods have been replaced recently.
Bump for suggestions ^^
Picked this up at the junk yard today looking for a rack and pinion (no luck).
Care to guess? +1 Rep point for first right answer! For those with one, you don't count :moon:
20130403_210224_zps41175e96.jpg~original
Actually, I haven't decided yet.. It would be the cheaper route for sure but would not be too excited about the extra in cab noise. It's one thing to carry a convo over the tires, but over the tires and intake, it would be noisy. An in cab screw on end cap might help with it a little.
Have you tried the rack adjustment?
IMG_0034.jpg~original
I have not.. does it get loose often or just all together need to be replaced? I'll check it when get home after work. I read the thread for the replacement. Seems easy, however with the amount of slosh it's getting on that side I'm assuming it's more than just the guide.
Plug it like I did with a pressure text cap for PVC. You can pick them up for a couple bucks at Lowe's. No noise in the cab at all until you pull the cap. I only pull mine when I'm wheeling so noise isn't an issue.
If you want to give the guide a try let me know, I have an extra one. I replaced mine troubleshooting sloppy steering but that wasn't the culprit. I can meet you in the Rock one day to hand off.
Looking forward to see if you do the in cab snorkel. I understand the need of a snorkel but never been a fan of huge crane neck on the side of my Runner.
Congrats! Looks like a pretty nice ring! My gf and I are moving into a new place with each other in a week. Bye bye 4Runner fund :( I figure if all is well by the beginning of next year, I'll propose. Scary to think that!
Does this mean dual cases are going to wait? :( Hahaha
lol It probably wont be anytime soon.. From now on my build will be pretty boring haha. Maybe but a few things here and there, but I doubt I'll be making any big time purchases for the 4Runner for a little while. I gotta get my timing belt maintenance done though soon, so I do have that to look forward to.
In light of things, I did order me a few goodies from RotoPax that should be here soon. Look forward to making the setup work.
patnewton
