Right on. 3" and up you're definitely looking at greater CV wear. You'll be replacing them before long. You may discover to improve/maintain ride and serviceability, you may end up travelling down the mod road...
I thought about going to 99 talls in the rear, but in time, they apparently sag like stock. I went with OME 880 front/906's rear, this provided roughly a 2" lift. I installed adjustable Rancho Shocks but I should have gone with Billies. I also went to 17" 265/70/17 slightly larger than stock... The ride is so much better now!
There are some real experts on suspension mods here. The problem is, once you start, you will find it impossible to stop, and the only thing that will get in the way, is that you'll have no money left!
Just installed OME 880/906s along with OME shocks front and rear and the ride is great. Not stiff and handles much better now. Ended up with a lift just north of 2”. I will continue to run 265/75/16s on it. Looking forward to seeing your build progress.
