KDSS lights on after rear spring swap
tnoble
Replaced the shocks and springs in the rear and now I have KDSS, ABS, 4 wheel drive light is flashing. Removed rear sway bar, dropped the axle and removed the springs. Installed new ones with new shocks, installed the swaybar back to the KDSS ram with ease. Not to sure where I went wrong. Has anybody encountered this before. 2010 4runner, KDSS pump was replaced a year ago. Everything was fine until I did the work tonight....
Contact Radflo RE: KDSS
I know Radflo the suspension company has done some research on the KDSS system in order to support their suspension systems that go on 4Runners with KDSS. You might want to call their tech support and ask them. Just a thought to maybe help out.
Good luck!
You probably pulled on one of the lines too hard. When you lowered the axle to get the rear spring in my guess is perhaps you didn't properly support the axle and let either a brake line or hydraulic line hold most (if not all) of the weight.
I have done this before with no issues before, hoping I didn't break a wire going to one of the wheels. Will check tonight as it was getting late last night.
