KDSS vs Non-KDSS?
Does anyone have the KDSS and an Aussie up front? I am curious because I want the get a KDSS TRD but want the ability to engage 4wd on road when it’s iced in some areas but not all such as bridges and chit but don’t want to feel a diff when in 2wd mode (Will be wife’s new car toting kid around).
Thanks all
I know this is an old comment, but definitely dont lock the axles on icy roads unless you just really want to be in the ditch
Other than upgrading to KO2 tires in stock size I have a stock trail with KDSS. I’ve done the Utah Backcountry Discovery Route and countless challenging trails all over Idaho and Oregon. Never been hampered by KDSS. To say the KDSS equipped 4Runner is any less capable off road is not an accurate statement.
Agree, inaccurate statement, did the WA Backcountry Discovery Route last summer, glad to have KDSS. Also KO2s, did have upgraded suspension OME BP-51.
I currently own a trail with KDSS and enjoy the on road benefits. I had the opportunity to rent an SR5 without KDSS for 4 months and noticed a slight difference in cornering on road.
The SR5 I rented seemed to lean more into turns even though the suspension seemed slightly stiffer when driving it on the road. Offroad, I think the non KDSS version was slightly better. I did not scrape the skid plate as much, and the suspension seemed to perform a little better.
My KDSS equipped trail version does really well offroad considering it has the locker in the back. I am unhappy with how the front skid plate hangs about an inch lower and sits farther forward from the axle than the non KDSS versions (This increases the approach angle). I have bottomed hard several times on the skid plate after going too fast over a water bar and nose driving onto the flat trail. I hope once I get bigger tires the problem will not be as bad and the truck bottoms more on the bumps stops instead of the skidplate on the ground.
I ultimately choose the KDSS version because I drive 99% on the road (including driving up to off road trails). The sway bar in front was enough to sell me as it twice as thick as the non KDSS version. After driving the SR5 for a fair amount of time and then getting back in my KDSS trail, the difference was noticeable on road. The offroad benefits are negligible due to the lousy front skidplate. I think the KDSS and non KDSS versions are about equal as far as capability, it’s just the KDSS version will have you clenching your teeth every time you scrape the skidplate on something stupid.
In the pictures below, the KDSS skid hangs down about inch lower than the SR5 at the lowest point, which happens to be the apex of the approach angle. Copy these photos and toggle between the two of them to see the difference.
Nice to see the differences in clearance. Are those factory or aftermarket skids?
These are both factory skid plates, KDSS top picture, non KDSS bottom picture.
erinobr2000
