kevinpt's 4runner
hey man nice build thread got base going. might need you to take some pictures of my rig sometime it could use a small photo shoot here soon
anyone have the winjet yellow fog lights from Carid.com
comes with everything to wire lights so i think im just going to switch out the housings and use the wiring kit to run other lights.
main question is by just switching out the housing and then using the wiring kit to install aux lights is that cheaper then buying all the parts to wire lights with a stock/stock looking switch?
installed winjet yellow fog lights. they are great build quality and really look amazing. only really big difference between this and stock is they dont have a reflector in the center like stock and bulb is rotated 90 degrees to what stock has. there is plenty or wire for the fog lights so its not a problem.
5P8A8149_zpsfca5920e.jpg~original
5P8A8151_zps900af9b9.jpg~original
just another cheap mod
i put some 250lb test rope on the cargo area hanger things.
best part is it closes up and is not seen, its a cheap and simple mod. now i can put a rope or anything else across and hang stuff in the truck
IMG_20130428_190925_zpsd93ef7a3.jpg~original
IMG_20130428_191415_zps32e4972c.jpg~original
ok so im going to plasti dip my rims tomorrow and need opinions. im thinking of dipping the rims and not the center caps. so what do you guys think, plasti dip the center caps or leave them silver?
finally dipped the rims. i think it looks a whole lot better this way. only thing i didnt like is how hard it is to take off the center caps. if anyone knows of an easy way let me know. one thing i learned when doing wheels is to use quarters on the lug wholes with a little piece of tape on them to pick them up by. that way you dont get ripping when installing. also used my dads tundra with tonneau cover as basically an oven to help make the plasti dip set up really well.
and the finished project. i dont think there are that many people with black limited rims, i really like the whole silver and black look i now have with my truck
5P8A9280_zps41ffc8be.jpg~original
5P8A9281_zpsb04ee190.jpg~original
5P8A9282_zpsf9aa92e6.jpg~original
looks good, I actually just picked up 4 cans of plasti-dip to do this same thing one of these days.
you should plasti dip the centers, Make sure you got alot of coats of plasti dip on them because i didnt and it didnt just peel off if you need it too, i had to pressure wash it off and it still didnt all come off. Im probably gonna just paint mine this time cause its easier to touch up but the plasti dip look is really good, i like flat black so im gonna try to find some flat black paint.
so as some might know i bought some trailer reverse lights a few months back and i think i have an idea.
i did a quick photoshop of what it would look like. tomorrow im going to find out if i have enough space between the bumper and the tow hitch. one thing is i dont know if the ridge in the bumper is going to cause any problems.
here is what im thinking
6-Oval-LED-Reverse-Light-LED-Stop-Tail-Lamp-LED-Indicator-for-Truck_zpse939c5e2.jpg~original
Looks good plasti dip the whole wheel and cap. Also get black lugnuts. Get some HIDs in those lights too and those reverse light idea would be bad ads look really good too....let us know how it goes.
so today i made it so i can have A/C in my console. i can now put stuff like drinks in there and keep them somewhat cold.
to do this i just got a piece of pvc (i think its a bushing), a 2 3/8 whole saw and a cap.
4 hours later i have this
inside A/C vent
IMG_0937_zpse0b5f928.jpg~original
IMG_0938_zps841aa7b3.jpg~original
IMG_0942_zps77c8e8f7.jpg~original
all this for under $20, if you have the right size whole saw total cost would be $3-$6
finished my led foot well lights using the wiring that came with the lit running boards
next thing on the list is a front mount hitch that i should be ordering before the end of the month, then a lift kit this spring
IMG_20130815_202738_zps02a05485.jpg~original
IMG_20130815_202643_zps0e0294e1.jpg~original
edit: also did the map light mod wired the same
IMG_20130819_184248_zps7282d36b.jpg~original
Get you a lift man will make the world of difference, lookin good cant wait to see more from this.
inside A/C vent
the idea is nice, but it still warm in there while driving. you might want to buy those freeze packs and have them in the freezer b4 a road trip, so u can incorporate the ac hole.
last time i checked temps i was able to get about 34 degrees
Status on this.
