KiruxaT4R Build & Photos Thread
Any shots of your fridge mounted on the cargo tray? Trying to get some ideas. Are you running a second battery?
No photos and not much to take photos of lol. I just use a bungee cord wrapped through the handle of the fridge and clipped both hooks underneath the slide out tray. It's ghetto for now, but once the fridge is loaded and surrounded by camping gear, it wont go anywhere. Once camping is done I pull the fridge out. Once I have drawers built ill come up with a better solution.
No second battery yet, 48hrs on "HI" voltage cut off for ARB Fridge does not drain the battery but also does not always run the fridge...just enough to keep things nice and cool such as steaks and beers:)
Second battery system in progress.
Security
Well its been a while.
I just ordered the blackvue dr650gw-2ch dashcam.
This thing(s) is not cheap but offers anything one could want from a dual channel dashcam system. Installation report and user review to come....
dr650gw-2ch_zpsr5ninglm.jpg~original
Outdoors
I promised some photos of my travels so heres an update:
Spring Camping:
Deploy Mode:
063_zpsiceevw3x.jpg~original
Nature Shots:
157_zps1nqpvkhe.jpg~original
164_zpsfvfuer9z.jpg~original
158_zps4smpninz.jpg~original
154_zps6pvfanwn.jpg~original
Btw Fire Wood goes into X5 :bounce:
118_zps2jqgltla.jpg~original
Camping for Canada Day:
016_zpswmquovve.jpg~original
with some meat....
121_zpssswr0jls.jpg~original
I need to get SLR camera.....
Great looking setup, the rims look great with the white. How are you planning to hook up the dash cam?
The dash cam will be hard wired through the module "Magic Power Pro" (comes with it). The module has a battery voltage cut off levels, as well as, on/off switch. This will allow me to record in parking mode or shut it off if the truck is in a garage for a week for now. Once I install the dual battery system, the switch can be left in "ON" at all times and records any disturbances while im away from the vehicle.
Essentially it will be a CCTV for my truck or black box lol
Detailed report with photos etc. to come next week.....
the interior and exterior lighting you changed out for LED's
So far they are super bright still and none have burnt out. I do have to say that pure white can be a little intense on the eye but it does light up the interior very bright when you are looking for stuff, especially camping, especially after few rums lol
Love your rig. I'm expecting my '15 TEP in a week and plan on the Countersteer Type X wheels also. I look forward to your updates.
End of Season
A few photos from end of camping season for this guy as it starting to get a little colder here in Alberta and its time to move onto hunting season:
064_zps4jfcr0xe.jpg~original
058_zpsmeelvauv.jpg~original
053_zpsebr6bv62.jpg~original
072_zpsnd4dnubp.jpg~original
Hunting Season.
Monday morning drove about 100kms out towards Jasper in hope to get some waterfowl and explore a new hunting area. Apparently it rained there which made for very muddy and clay like conditions but about 80kms of back country roads explored.
A few photos and a short video:
https://www.youtube.com/watch?v=R3-Z-5OnRWY
5 Bananas out of 10.
As promised with a bit of delay, here is the write up for installation of BlackVue dr650gw-2ch.
Reasons to install:
- Capture of vandalism/hit & run while in park mode.
- Capture of an accident.
- Capture of an accident ( as a witness ).
- Capture of insurance scams.
- Capture of any cool moments.
- Capture of cool views/off road videos without the need for Go-Pro ( at least from 2 angles ).
The unit:
I placed the front camera as center as possible and in the front of the rear view mirror to hide it better from outside. 3M sticky tape is provided.
130_zpseex3qym7.jpg~original
I taped the 12V wire and the optics wire together for cleaner install, leaving just enough slack to be able to spin the camera 180 degrees in its ring housing.
128_zpsv5cc4ibu.jpg~original
108_zpsueyylht5.jpg~original
Route both wires under the headliner to the driver side A-pillar.
109_zps3nppvqgm.jpg~original
Route the 12V wire under the A-pillar stock wire guides and down to the fuse box underneath the panel.
114_zpsrspb8xkv.jpg~original
Route the rear camera optics cables to the back of the vehicle, tucking it under the headliner with the help of the provided orange tool. The B, C, D pillars pop out just enough to feed the wire through.
112_zpsq3zmwuob.jpg~original
The rear camera is supposed to stick to the rear window, however because our windows roll down I popped out the center clip of the headliner. Use the existing hole to mount a bracket (home depot) with a 14 x 1/2 metal screw.
I plastidipped both bracket and the screw in black.
172_zpsi4cq2tqg.jpg~original
I mounted the rear view camera with provided 3M tape to the bracket and angled it in the proper direction. As you can see the camera is out of the way and far away enough from the rear view window. This way, you can still load long lumber etc. and rest it on open window tailgate (I found this solution from another 4Runner guy from google, I take no credit for ingenuity lol)
175_zpsxcftyecf.jpg~original
173_zpsju374prk.jpg~original
Next I mounted the Power Magic Pro unit with provided 3M tape to the bottom of my dash. The unit has 2 wires for 12V plug, 1 ground, 1ACC+ and 1 Power.
The 1ACC+ was hooked up the ACC fuse. The 1 ground was mounted to the bolt holding the fuse box. 1 Power was hooked to the power seats fuse. Make sure to meter the fuse, to ensure load side connection :hippie:.
The way this unit works:
- First three dip switches are for voltage cut-off (in my case I chose 12V)
- The other three dip switches are for timer (I chose 6hrs = 6hrs of recording in park mode)
- ON/OFF switch for shutting off the camera manually once the vehicle is off.
123_zpsaeiprtdx.jpg~original
118_zps2frsab7g.jpg~original
The 12V power wire has a male plug, insert it into female 12V of Power magic pro unit, roll up extra lengths on both sides and mount it underneath the dash. I mounted mine in accessible location so I can still unplug it if needed.
I did not shorten any of the extra lengths which would provide for a cleaner install, in case I ever in my life have to take it out of this vehicle to mount in the other vehicle.
116_zpsqn3f0iug.jpg~original
121_zpszu0m4egu.jpg~original
Nothing is visible from outside but 12V cigarette plug is still accessible.
124_zpsesetyh70.jpg~original
View from outside:
126_zpstonekafj.jpg~original
View from driver and passenger sides:
131_zps3w45joxd.jpg~original
127_zpsrr7ncgfe.jpg~original
All the options and what the dashcam can do, you can go to blackboxmycar.com and do your research ( too many things to list)
The app Wi-Fi works pretty good so I can review any of the videos it records in 1min lengths at any time while driving, download to my cellphone and save. Also, you can adjust configurations and settings for sensitivity censor, G-sensor and all other misc. options from the APP. Simple swipe on the shiny screen on the left will turn ON/OFF the audio recording of your passengers conversations (could be used in arguments with the wife :bounce:)
Here are sample videos for you guys, I made these just for you because i'm a good guy like that (make sure to select HD mode as what the cameras records in at 30FPS):
https://youtu.be/EmxNyDS4AT4
https://youtu.be/HhLmC_oSM-Q
https://youtu.be/q3EYB2QmCDE
I love your build! We just bought a 2016 SR5P in super white, and I'm getting my bronze countersteer X's wrapped in Ko2's tomorrow! Eventually I would love to do a GOBI rack and the N-Fab sliders as well... basically I'm just a soulless copy cat of your build! Love it. Did you notice any change in driving dynamics going to those aggressive AT tires and the lightweight FN wheels?
I might have missed it, but why did you switch from Frontrunner to Gobi? You mentioned weather issues in another thread, but I wasn't clear what you meant.
2001ATL
