LC 8 wrap question which combo......?
Ride_Red
So, I am currently running the 890s w/5125s in the rear and I'm looking for a little more lift plus a softer ride. I don't mind the A Team rake at all.
I have some drivers side lean so, i had to put a trim packer on the d-side. Thinking about doing LC 8 wraps. What combo do I want to use?
This is what I was thinking......
Drivers side - 20.25" Blue Yellow White 8.75 wraps-one of these is a confirmed LX450
Pass side -19.5" Green Yellow White 8.25 wraps-one of these is a confirmed LX450
Does anyone recommend a different combo?
7 wrap is about 3-3.5" of lift
8 is about 4"
9 is about 5"
Height of spring/color code/wraps
21" Blue Pink White 9.25 wraps
21" Grey Orange White 9.25 wraps
19.5" Purple Green White 8 wraps
19.25" Double Purple Dark Blue White 8 wraps
19" Double Pink Light Blue White 7.5 wraps
18.5" Double Pink Grey White 7.5 wraps
18 7/8" Orange Orange White 7.75 wraps
I run:
I run eibach fronts with tundra bilsteins on the first notch and a toytec 1/4 inch spacer and my rear sits about 1.5 inches higher. Awesome smooth ride though, lots of flex too!
my set up is
with bilstein 5150's
i have tundra struts ready to go in and an unidentifiable set of OME struts currently. about an inch of rake but not bad... i love the ride with the bilsteins.
is .25" enouogh to compensate for the drivers side lean with these coils?
Cause if I go the set-up below, then I'm at a .75" difference between the two sides?? Too much?
Can I use a trim packer to compensate?
Just a little info I found on the hours of searching I did for mine. The two you have listed for the LX450 are softer coils. Everyone said they aren't as stiff as the ones in the FJ80s. Basically they wanted a softer ride for the Lexus, being a luxury SUV. They may be a bit too bouncy is what I took from it.
I went with the purple green white, double purple light blue white being I'm planning on a rear bumper with tire carrier.
Good to know!
Since I personally think the 890s are little too stiff and some saying the LX's maybe too soft. Then here is what I ordered. I figure if I don't like one set, then I'll swap them out. Better to have options. Should have both sets by Friday.
Picked up both sets today!
I was even tempted to grab the 9 wraps for the hell of it, but decided not to.
If the weather is good, I'll install the LX coils this weekend to test them out.
2358A8B0-9C96-4512-8708-C346E2D1B971-559-0000006E15647313_zps3cc39741.jpg~original
Sweet! Let us know how the LX coils ride and how much height you get out of them. I am interested to see how you like them.
