LC 8 Wraps - Trim Packer Needed?
d0nkeyxpunch
I have pair of LC 8 wraps straight out of '96 Landcruiser. Driver side spring is tad taller than passenger spring to compensate for gas tank from factory.
My question is, do you think I should add another 10mm trim packer on top for the driver side on my 4runner? I want to eliminate driver side sag with me in it. I am 180 lbs and not going on diet anytime soon if that matters.
You and I are the same size I did not have to add trim pack with new springs. Your left front spring makes a difference also it should be longer than Right front.
Hmm....so it sounds like I need to get spacers for front vs rear? I'll be installing Wheelers T1 3" coil with Tundra 5100 Bilsteins in front.
Ask Wheelers if their front springs are side specific before ordering something you may not need. My tundra & 8 wrap lc springs were side specific it sat level. But springs were new.
My LC springs came from a Sonoran Steel kit and they each have the same paint code and I had a drivers side lean even without my 230 pound rear end sitting in it. So I added a trim packer . I don't think you're going to need to though . I believe that the Wheelers springs are the same Eibach springs that Toytec sells , and if so then you will need something to level the front . I leveled mine with the Tundra bilsteines . The passenger side is on the lowest setting and the driver side is on the 2nd . Leveled out nicely .
2001ATL
