Leaking Front Diff
Running into the same problem. Did you get it taken care of?
I've cleaned it up, drained the excess fluid from the front diff, and replaced the breather (check valve inside engine compartment/driver's fender), but have not warmed it up enough to tell for sure. Will try it out in a week or two and report back.
Inside the breather is a spring and a rubber/plastic/neoprene valve. I'm not confident that it would work properly after gear oil has been in there. $5 at the dealer. 90930-03136 for 2001 SR5
erinobr2000
