Led interior lights ??
Traveler74
I am considering replacing my interior overhead lights with LED lights. 2 over the dash and the dome light. Do I need to replace the entire fixture OR can I merely replace the OEM light bulbs with LED light bulbs ?
If I have read correctly, LED lights use much less amps. If so, there should never be any problem with blown fuses.
Yeah, just replace the bulbs. I got mine from VLEDS They've got a great product selector based on vehicle. If I were to do it again, I'd probably go with the panel type swap instead of the bulb-sized led replacement. They're not bad, but I wouldn't have minded brighter.
On a side note, if you decide to change over your turn signals to LED you'll need a different flasher relay.
AndiGarage
