LED Lighting Kits
List has been updated:
4.Lava rocks - 5th gen 4Runner under hood lights (warm white) both switches
9. NZDZRT - 5th gen hood kit, manual switch, warm white
10.toy4runner - 4th gen 4Runner under hood lights, warm white with both switches
11. wmiranda - 4th Gen (2004) Limited V8, Hood Kit, warm white, both switches
12. RunnerLimited - 3rd Gen under-hood lights w/ pin switch
13.SoCal4RunnerTrail - 5th gen cool white under hood kit w/both switches
14.cr_co_4rtep - 5th gen 4R. Under hood kit- white - with both switches
15.Chim - 3rd gen 4R. Under hood kit- white - rocker switch
16. Ohio_steve - 5th gen 4r. Under hood kit - warm white - manual switch
17. pbealo - 5th gen hood kit w/pin switch, white
18. MyHigh - 3rd gen hood kit w/ , white
Please if you'd like a kit add your name to this list. Copy the post and add to the next available spot.
Yes sir that's correct.
Ah, gotcha, thanks for the clarification, [MENTION=135198]Dane2992[/MENTION]!
In that case, I'm in for a set myself.
19. JustSomeName - 4th gen 08 4x4 v6 hood kit; cool white, both switches
19. JustSomeName - 4th gen hood kit; cool white, both switches
I only take $$ when the kit is ready. I only do this just because if something happens and I can't follow through, I'm not stuck with someones $$ and they don't have a kit.
List has been updated!
4.Lava rocks - 5th gen 4Runner under hood lights (warm white) both switches(paid)
Tracking numbers coming soon to those kits that shipped earlier today
Update. Tracking has been sent out.
Another happy customer. Finally installed my LED under hood kit yesterday. I was a 5th gen beta tester and included pics of my pin switch location and wire routing. Like pjbrownva states in post #92. This is a high quality kit. All you do is test fit, stick, route wires, install pin switch and connect to battery. I had no issues with the high quality terminals.
Happy to answer any questions. I then used my new LEDs to install the TRD CAI. It was great, didn't need my headlamp like I normally need working under a hood!
Pin switch location. The furthest right side (battery side) shroud attachment. Just replace the plastic clip with your pin switch. I chose this spot because it was close to the battery, the body hole was exactly the right size (the switch actually loosely threads into the hole). And there were minimal modifications to the 4Runner. I only enlarged the hole in the plastic shroud. At first, I tried to avoid modifying the shroud but found out I did need to adjust the height of the pin switch and didn't want to pull the shroud on and off to do so.
The one con with this location is the limited access to the underside nut. A steep angle with an open end wrench and flipping the wrench after each 1/4 turn with a mirror to see what you are doing did the trick.
When selecting the pin switch location I loosely installed it and put chalk on the top to see where it would contact the hood when closed.
Make sure you remove the paint to bare metal for a good ground.
Here you can see the wire routing. I also went under the hood pad at the corners of the light strips.
Here is the wire routing from the hood down the hole by the hinge and along the inside wall to the battery.
The fuse.
Finished results showing newly installed TRD CAI. You can save $150 by ordering the individual parts from Camelback Toyota. See my build thread for links.
Mine got in yesterday, but I was out putting my 4Runner to good use till this evening. Install was really quick, except I can't get the switch to work, is there a trick to wiring this switch? I'm using a blues seas fuse block instead of the in line fuse. Positive from the LEDs to the switch, and from the fuse block to the switch. And negative grounded? im using another switch i had laying around and it works how I have it wired, so wither the switch is bad, or I don't know how to operate this switch.
Your switch has two posts correct ( I had three post switches go out to some member's by accident) it simply could be just a bad switch. Are you using the same connectors on the other switch you had laying around?
Yeah I got a two prong. I'm currently using a three prong, but the third pron is just the ground for the switch's light. I tried both ways, but neither worked.
patnewton
