busmup808
Well not an expert in wiring, but not afraid to jump in it and finish. If you read on my truck, I've done more than a hand full of wiring installations. I also have a Blue Sea 12 circuit fuse block under my drivers seat and a 6 circuit fuse block in the rear of my truck running on dual batteries. You go through PayPal? Want the hood kit for a 3rd gen 4runner fo shua! Mahaloz and Aloha from WANo actual pricing yet. Still considering the mounting options. As I stated above, this is for the more experienced in electrical. I have not done this to my vehicle.
I would never put a switch to the rear. Waste of time when u can use what's already there like u did. I would not mount the LEDs with the zip ties.Agreed. If you are going to mount a switch for this kit it will require removal of some trim pieces and some drilling. You will also have to run wires all the way from the battery to the rear. If you go my way you'll need to splice and connect from the rear dome light. Either way I'd make sure your comfortable with what's needed before getting this kit.
Sent from my SM-N910V using Tapatalk
sent from my Hawn fingers
