LED replacement for 4157NA turn signal/daytime light
wadeanderson
I have a 2005 with and want to replace the exterior bottom left bulbs that act as daytime lights as well as being the turn signal.
The bulb in it is a 4157NA, the bulb is amber.
does anyone know what LED could be used there?
and best place to buy?
thanks!
I'm waiting for V3 Amber Triton from Vled to come in the mail, will post pics upon install. Don't forget resistors when you do go LED unless you like quickie blinkers. I also got em for the rear to match led taillights.
where would I buy resistors? same place that sells the "V3 amber triton"?
is that something I just splice into the wire near the bulb socket?
I have a all led set up on mine and they are plenty bright without the high cost of tritons.. I got a set from ijdmtoy that has the resistors built in so you don't have to splice anything
I found idjmtoy selling the lights through amazon but I could not find the ones with built in resistors. Do you have a part number? Someone else told me to get "Cree" bulbs and that is what is stated on the idjmtoy ones.
I checked with ijdmtoy and there 4157na bulbs do not have built in resistors.
here is what they said to me:
We do carry some LED switchback turn signal bulbs for bulb size 4157. You may take a look at the product here - 3157 3057 4157 Dual Color Switchback LED Bulbs For Turn Signal Light
It will be white on driving and flash amber on turn signal, then back to white when the turn signals are off. Unfortunately, we don't carry this product with a built in load resistor so you may need to tap load resistors into your turn signal's stock harness.
Here are the resistors - 50W 6Ohm LED Load Resistors | LED Turn Signal Lights Hyper Flash Fix
You may find the installation guide on the same page.
I checked another company too, SuperbrightLEDs.com also said theirs do not have built in resistors.
Does anyone make them with built in resistors?
2001ATL
