sam.basye
Member
What flasher relay are you running with LED turn signals?
I have one 7440a LED in the each tail light and 12 amber 9w "eagle eye" LED's up front: 6 per side wired into the stock turn signal wiring..
The stock relay hyper flashes left and right signals, but normal with hazards on. (I had stock incandescent bulbs in the rear at the time)
I have tried the EP35 LED relay which hyper flashes.
I am currently using the adjustable EP35 relay which works normally for a week, from then on it clicks an extra time after turning the signal off.
I have gone through two of these in 6 months. They eventually stop powering the rear turn signals and the fronts start to go dim and flicker after about 3-6 months.
The third, and current one started the clicks after turning the signal off issue right out of the box.
This one however has an additional problem.. It flashes normally, then speeds up, then it slows down if left on while waiting to turn. It repeats this over and over.
It's rather irritating..
Does anyone have any suggestions??
