LED turn signal problems
Mellob
Yes I have searched through the threads and this is what I have tried so far: I purchased an ISO LED relay off of ebay (doesn't work but I get a weird ticking from passenger side behind dash); went and got an EP-35 led relay from local auto store (ticks but still nothing at the lights); originally added resistors (hypered the regular lights but nothing out of leds). I am getting more than discouraged here. I have LEDs for all four corners. (oh and when i was adding the resistors occasionally they would light solid and not flash, so they do light up). Any ideas?
Also I have the LED taillights (the whole unit; brake lights and reverse; came with incan turn signals), when I turn on hazards the brake lights flash but fronts do nothing.
id just stick with the stock flasher and put a resistor on all 4 turn signals.
your turn signal stock may be worn out, if you flip it does that make it click fast(without the light flashing). if so, just pull it back to center slightly whenever you flip it.
Put stock relay back in. When I turn signal on it buzzes continuously; both directions and hazards. Don't even get hyper.
Well apparently it matters which way you put an LED 7440 in, and apparently I put every single one of them in backwards. Who knew? (Probably you guys)
