LED turn signals - hyper flashing and how to fix?
hobosapien
I just had my bumper installed (Demello) along with their LED turn signals. They were attached directly to the wire relay of the old harness and it is now hyper flashing.
Is there a way to slow them down back to normal?
take a peek behind the driver side fusebox inside, and see if your truck has the 8 pin flasher, usually if you dont have drl, its a 8 pin. flasher relays are only 20 and under.
Sorry if I'm confused - are you saying I can replace the fuse to slow it down?
Get the electronic flasher unit the riceandpho suggests. Much safer than the resistor setup and easier.
he has a 5th gen, not sure where the unit is, maybe its the same behind the fuse box.
Yeah, I'd be all for ordering that one but my concern is that it may be a waste of time just because it may not work for my gen/year. Trying to find a service manual.
I have a 2004 with DRLs.
I just want to make sure, is this the correct flasher to get?
https://www.amazon.com/81980-50030-066500-4650-Electronic-Flasher-Toyota/dp/B008C9YS0Y
It says it does NOT replace your flasher? so how does it work? Or is there a way to just replace the flasher?
Also are there instructions on how to replace the flasher, I couldn't figure out how to get to it.
DRL-equipped 4th-gens like yours use a different flasher relay which uses a 12-pin connector, non-DRL 4th-gens use a 8-pin flasher relay like the one you posted from Amazon. Long story short, that flasher won't fit.
H.Sikina
