LED's for turn signal won't turn on :/
itzTHIZkid
so i have a 1990 t4r v6 3.0 auto, so i was switching my turn signal light bulbs to leds but when i swap them the leds wont turn on at all, any one has any idea why?
More than likely the Led's dont have enough resistance to activate the turn signal flasher.
Try using the emergency flasher, they should come on then.
There are 2 ways to fix this.
1. get a electronic turn signal flasher for led's
2. You have to put resistors inline at the bulbs. This way the flasher thinks your old bulbs are being used.
well i already have the flasher, it just got here today, just need to find time to put it in hopefully it will work,, the flasher should be located by steering wheel right?
Alright first. Did the lights work with the stock bulbs?
Do any lights work with the hazard lights on?
What brand and type LED bulbs do you have?
When it comes to electrical problems, you need to state specifics so we can better help.
lights work with stock, change the flasher the stock lights still work, the stock lights work in hazard but not the LED's also in just the turn signal they dont work, to tell you the truth dont know the brand of the LED's but they are 1126 type bulb
well its the bulbs you are trying to use.
both flashers, turn signal switch and hazard switch work. Wiring is good since everything works with your stock bulbs. Sounds like these LED bulbs are garbage.
Rialm
