Left front fender replacement '91 4runner
pat roberts
I bent up the left front fender just in front of the door. Where can I find step by step instructions for fender removal and installation? Thanks, Pat Roberts
It is just a matter of un-bolting everything that holds the fender on.
you should be able to just eye ball all the bolts you need to remove/under the hood, inside the door, you will have to remove the bumper and side marker too, plastic wheel well etc. not hard to do just time consuming.
Just take your time and bag all the bolts you remove.
If you need help along the way just reply to this.
Hope this helps
mike
Mike: Thanks for your help. The car has 215,000 miles on it and I don't want to put any more money into it than necessary. I am a fairly good shade tree but have never done anything with the body. I'll follow your advice. Pat
I think you will have no problem then/reply if you need help/good luck
peacefulpiranha
