Left rear power door lock issue
034G
Just noticed that my left rear door (rear passenger door on the driver's side) no longer locks/unlocks when I hit the power door lock button inside the vehicle or use the alarm to lock/unlock the vehicle. I put my ear up to the door and hear no noise from that door panel indicating the power door lock is still functional. FYI: it's a 2003 SR5. Any suggestions?
You may need to open the door panel. Maybe the wire is loose or disconnected somehow.
Had that happen to me as well (I had to take the door panel off and disconnect the wire to put in new speakers...well, I did not put the wire back in place the right way haha)
But in your case, since you don't hear anything, you probably need new door lock solenoids...
Before you spend mega chedd on new solenoids, take the door panel off and make sure the lock/unlock cable is snapped into its appropriate place. Its a ball and socket fit. my back passenger door came out one time and wouldnt lock or unlock and this solved my problem.
I know this thread is old but I just purchased a 05 4runner sport edition v8 with the rear left door actuator not working and was wondering what I would need to fix it. Just ordered the part but new to working on these vehicles and would prefer to save some money since I'm a college student. Any help would be much appreciated!
Link
The link above is still up and relevant. You might have a different price on the part, but everything else still applies. Good luck with it, not a hard job.
ronjon13 That blog post I made a while ago still works. I was able to find the repair manual online and used that as well. Unfortunately I am unable to attach that to this reply or to my blog post. I did some quick looking around but could not find a free download for a 2005. I did find it for sale on Rock Auto 2005 TOYOTA 4RUNNER 4.7L V8 Repair Manual | RockAuto
I hear there is not much difference so you could probably use the free 2003 manual to replace that actuator. The following link still seems to work.
Service Manual Download Links.
I recently replaced my right rear door lock actuator as well and took pictures for a writeup. I got the actuator from Actuator Plus on ebay for $60 after shipping. They're rebuilt with Toyota parts and have a lifetime warranty when you send in the core
Link to my writeup: 4th Gen Door Lock Actuator Replacement: Step by Step with Pictures
edit: I see that you already ordered the part, but the writeup will still be helpful. It was pretty easy and I'm a college student on a budget as well. I do recommend the harbor freight panel clip pliers, they were pretty helpful for removing the door panels. See writeup for full details
Yes, this. Same thing happened to mine. Was a very easy fix.
I took things a little further....
For 22 bucks I bought four DC motors off of eBay. I then replaced the internal motor of each door lock actuator.......still have to do the rear doors.
It's a bit involved, but if you have a workbench.....and go slowly......you can save a bunch of money.
Hope this helps.
Kevin
TerryNap61
