Lets see your CB setup.
racedirt1
Done with the crappy hand held, Christmas yielded a new Uniden 520XL. Lets see some pics of your antenna mounts.
Don't have a pic, but can get one in a bit. I'll leave this as a placeholder till then. I mounted mine to the rear left bumper. I have a 5 foot Wilson fiberglass silvertip antenna. get about 10 mile range. have to take it off when i go into a parking garage though.
i had a 520 in the ash tray fit realy nice too heres my antenna wilson 3ft flex gaint spring just looks cool dont need one though stainless fender mount and 18ft of firestik fire ring coax
2ee8870d.jpg~original
I just picked up a cobra 19 ultra iii. Im assuming I have to take out where the ashtray mounts to be able to mount the cb in there? What size is the cb antenna your running? Any pics of how it mounts to the TJM?
Wiring this thing is gonna be a female dog. The red/black power cables are only a couple feet long and won't reach to the battery. Where the **** am I gonna pull the power off of to power the cb?
wire it to the fuse block (under the dash), and then ground it to anything metal attached to the chassis.
You can get a "Mini fuse add a circuit" at the auto parts store, these make it really simple and easy to wire up accessories like CB's and such
I put mine in the same time i did my HU, i tapped into the full time +12 on that so i can still use it with the truck off. its got a built in switch that way.
With my suggestion you can also have it run when the car is off, just find out which place on the fuse block has power when the car is off. Use a circuit tester.
So if I pick up one of those, I just solder the red into one of those fuse connector things and ground the black, and put that fuse thing in an empty slot in the fuse block (assuming there is an empty slot)? Thanks this looks like the simplest way
Yep, and you don't even have to solder, you can just crimp it. And I know there are a few empty places on the fuse block under the dash, there are also a few under the hood too on that fuse block. And if you have to get more wire that's easy too, same section in the auto parts store.
I don't want to discount what twitchee2 said though, you can also tap into any power wire too back there, something like the cigarette lighters/power ports, that would be fine too. But I prefer to use the add a fuse thing.
no pics yet but I will get some up to my Facebook
I tapped into one of cigarette lighters as mentioned by jsmarine- I don't need all of them myself. It is switched (only comes on when ignition is on)which I thought was wise so I did not leave the CB turned on accidently and draining the battery.
Just add some more wiring if you want enough room to pre-wire in there and pull out your CB. It does help to have a second person around to hold wiring out of the way and so on while you make the connections. Start with the ground first so you don't blow a fuse...there is a good ground connection right behind the radio bezel-down and to the drivers side.
As for placement of the CB itself -mine was small enough to fit under my Sony head unit- I mounted it flush to the left side and used plumber's metal strapping band to wrap around my head unit and used the side (knob) screw ins for my Midland 1001Z.
Antenna easy for me- I have the ARB bumper up front and just drilled out a slightly bigger hole from an existing one near the center.
Good time to add a power antenna switch while you have the dash all apart, and I did the antenna combiner mod as well. Here is link from our good buddy Rock Slide over on Yota Tech:
Guide on How to Combine Both Front & Rear Antennas into One on an Aftermarket Stereo - Page 2 - YotaTech Forums
Also read a great idea-if your head unit has an auxiliary input jack(?) that makes for a great use for an external speaker, just run a mini to mini cord from back of your Cobra to poke out the front. Then you can hear your CB through the radio speakers when you put head unit on aux setting.
Heres my Firestick
<a href="http://s94.photobucket.com/albums/l93/evalencia102001/?action=view&current=IMG_8461.jpg" target="_blank"><img src="http://i94.photobucket.com/albums/l93/evalencia102001/IMG_8461.jpg" border="0" alt="Photobucket"></a>
Awesome idea Ron, I'm definitely going to do this. About to head to a buddy's house for a few brews on this lovely Wednesday afternoon and install the CB. Wish me luck:lol:
no i hate hate you forgetting to have such a great day while stuck at work, i can only wish for beers a cb uint and a nice day to work on the truck right now.......aaahhhhh lucky bas****!
lol, seriously though good for you man let us know how it goes!
I went with a magnetic mount Wilson Little Wil for my setup. Don't really like the antenna on the bumpers look and wanted to have good range and reception. I got mine tuned and so far I have always had better range and reception than anyone in the groups I have gone out with. Plus I can totally take it apart when I am not using it.
