Leveling kit questions
Jcalderon
I have a 92 3.slow with an auto 2wd I want a leveling kit but all the ones I see say for 4wd I look at the parts and they look no different from what I got balljoint spacers in the front and spring spacers in the rear so does anyone know what the difference is or will the kit fit???
I think the balljoint spacers are different. I'm pretty sure I remember seeing on 4crawlers site that he sells a different set for 2wd trucks.
Just looked it up on the site u told me about and I might b ok said some 2wd models came with the 4wd suspension except took out the main parts witch is what mine looks like, has the brackets for the front diff and everything, plus it said sometime about the holes are closet together on the 4wd and farther apart on the 2wd like one is 4 inches and the 4wd is like 3 so pretty much ill find out if I'm out of luck on the fronts when I get them in and try to install :/
goddesszilla
