Leveling Kit
Smitsyoda
What leveling kit would i need to make my 2004 SR5 4wd perfectly level with the rear? I did a search and couldn't find it. Is it a 2.0 or a 2.5 front spacer lift? I don't want the front to be to high then the rear nor to low.
Thanks.
Thanks.
The lift FAQ section at the top has a ton of details.
There is about 1-1.5" forward of rake. So if you do a 1.5" front and no rear it will be level. Most do the 2.5" front with 1.5" rear. Keep in mind the OEM springs are pretty oft so adding a heavy box in back will lower the rear....
Only 1.5 makes it level with oem rear? I tought it had to at least be 2 inches to be level. I just want it dead even if possible. I was thinking go with 2.0
Daystar Budget boost runs about $40 and gives 2" lift. I know galactic_04 is running a 2" lift in front and stock rear, you can check his out for pics.
I think it also has to do with v6 vs v8 and how much spring sag you have. Go with 2" and call it a day.
Jhunt
