license plate light fuse location
ColoradoMTNlivin
Anyone know where I can find the fuse for my license plate light? From what I've read so far it should be in the fuse panel on the drivers side by the steering wheel, it's not labeled though. I can't figure out which one it is. It's a 99 sr5.
Thanks!
That fuse is fine, I suppose there's a chance both bulbs are burned out too, I just didn't think they'd both burn out at the same time... anyone have any ideas?
If its not the bulbs, its probably the wires running between the body and the hatch. They bend back and forth every time the hatch is opened and it is pretty common for them to eventually break.
Did you ever get that fixed? I have the same issue and am curious if your lights were burned out.
I lost my 3rd brake light and hatch lock/unlock due to broken wires in that rubber wire loom between the two. Just pull it back and I bet you will find a broken wire
Cpn2mss
