Lift and Tire Central (pics)... Post 'em Up!
Thanks to my buddy Gaterose I finally got my Bilsteins 884/Superflex installed today. It was getting late so we were just able to grab some cell phone shots. Even though it was some hard work it was great hanging out and shooting the breeze. I will get some better pics tomorrow.
Nice new look! Your 4r is really riding high! I like it. How many inches it from the ground to the top edge of the wheel well now?
Thanks. I just measured
Front Right - 38 1/2"
Front Left - 39"
Right Rear - 39 1/2"
Left Rear - 39 5/8"
Can finally submit.
It's been a while since I've posted anything but here are a few pictures with the 3" OME lift, 285/70R17 Trail Grapplers and 17" Fuel Hostage wheels. Sorry for the iPhone pictures but I don't have any other camera. Enjoy!
Are you claiming a 4 inch lift in front and 3 inch lift in rear with your current 5100+OME set up? I was under the impression via reseach OME springs gave about a 3/2 lift. Let me know as I'm curious. Looks awesome.
Thanks man. you are correct. The 884s+small spacer OR the 885s should provide around 3" lift. However, when preloaded, the 884s lift much more than the .85" setting would suggest as those estimates are derived from factory rated coils. Before the 33" STTs with my crappy, worn down 265/70 highway tires, I was sitting around 38-38.5" (center of fender to ground measured through hub's center). With the 33s, I'm a little over 39"....~40" in the rear.
Good morning all!!! Thought I would throw my junk up finally .
Stock
05 v8 limited
Icon 2.5s with TC upper
Lower BAMF Arm Skids
Rear OME for now
Goodyear Kevlar tires
This is what I came from, the 4runner is a step up in power and gas mileage for sure!!!
OME 895/885 265/70/17 Cooper ST MAXX
Just got on my OME 885/895 installed. Used the no compressor method. Front is 38, rear is 39, so almost dead even. Love the ride with Bilstein 5100s at the lowest setting! Oh and if you notice they are silver that is becuase i painted them to match my calipers/ titanium paint.
I only needed new shocks......
so after researching new shocks, I came across the wealth of info on this thread and figured why not lift it some too at the same time.. Tons of great info on here, and learned a lot to say the least - I appreciate what was provided here. Now that my stock shock install turned into a few more $$'s than expected, I thought I would share some photos and some insight on my install.
I had originally bought the daystar lift, but ended up returning it and when ahead and bought the complete OME suspension kit from toytec (which is about 6 miles from my house - great group of people there too) - after the tires - p265/70/17s, this is what I ended up with -
2003 - V8
Bridgestone Revo 2's
spidertrax wheel spacers
the diff drop kit (toytec recommended)
OME 884 front coils
OME 90000 sport shocks for the front
1/4 top plate spacer (the 1/2 inch is the default spacer when ordering this kit, so I replaced with the 1/4 inch). My wife was overwhelmed at the lift at first, so the 1/4 inch top plates are off for now - bummer. Although I am ok with the little bit of rake.
Toytec superflex rear coils.
OME 60020 rear shocks.
I had a lot of questions about how much lift the 884 vs the 885 coils, top spacers, etc would provide, and after a lot of searches, found that others had the same question, so I can provide my results at least for the 884s in front with and without the 1/4 spacer. - hopefully I can provide a little insight based on the cost of having to remove them for now.
The 884's alone provided right about 3 1/8" of lift in the front, and the 1/4 inch spacers provided another 3/8 inches of lift.
The toytec coils have provided 3" lift in the rear.
After the install, I did note some CV joint grease that has come out of the inner boots - after cleaning that up, I have not noticed any more - hopefully a one time thing. The ride is definitely stiffer than stock, but I like it.
the front edge of the tires did rub slightly against the wheel well liner, I did move those forward, and all is good now - would be happy to share about that as well.
After one week with the install - a couple of questions. Should I expect the lift to settle any in the front or back- so far it has not, and really hope it doesn't. Will the shocks and/or coils soften up a bit after they are "broken in"? Should I be concerned with the CV joints spitting out some grease after the install, and get those repacked??
thanks in advance -
Well this is only my second post. But seeing as though others were posting pics of my vehicle. I thought maybe it's time to post my pics.
Well I figured it out so here is some pics. Other upgrades include ARB roof rack, front bull bar, and air compressor also just added the Rigid lights 40 inch on the fronts and Dually D2's on each corner of rack. CBI rear bumper should be here and mounted after Thanksgiving. I would welcome any criticism or suggestions
Lift option.
Will this lift option give me 3' front and 2' rear?
OME 886 Spring Set 160.00
OME 895 Coil Set 160.00
Bilstein C477 Front Strut Set 170.00 170.00
Bilstein E703HO/33-187174 Rear Shock Set 143.00 143.00
REV RTDD2-KB Diff Drop Kit 24.00 24.00
T4501-2 Top Spacer Pair, No Studs 52.00 52.00
Or should i go with this lift?
3" Lift W/ Bilstein 5100 Height Adj Coilovers FJ/4Runner
Price per Unit (Kit): $889.99
--- TTHA-CK-RCC
Complete 3" lift kit for 2007 & UP FJ Cruiser and 2003 & UP 4Runner with Bilstein 5100 Height Adjustable front shocks
INCLUDED IN KIT----
Front Lift:
Fully assembled front coil over using Toytec aluminum top mounts and urethane bushings:
- Bilstein 5100 height adjustable front shocks
- Toytec/Eibach 112620 front lift coils
Preset at 3" front Lift and able to carry extra front weight.
Rear Lift:
- 2" Rear Lift "Superflex" coil springs- 10% increase in load capacity/spring rate and a great ride quality.
When used with provided shocks they add 2” of more overall rear “flex” to the suspension
- Extended length Bilstein 5100 rear nitrogen gas shocks for optimum performance on and off road
Also includes:
----- Toytec Lifts Front Diff Drop Kit
Well... I don't think I've ever posted pics up here, so it's about time. I've been concentrating on my 3rd gen, my 4th gen is pretty much the way I want it except for maybe front and rear bumpers in the future. Here she is:
Happy Thanksgiving!
Don't think I ever posted a shot of my rig. Not a really clear shot of the lift, but my current setup.
Front: ~40.25 inches (ground to bottom of fenders)
Icon Coilovers w/ reservoirs up front
SPC upper control arms
Rear : ~41.25 inches
Icon 2.5 Piggyback reservoirs
Allpro offroad 3" coils
Medic swaybar links
Firestone Bags (for towing)
1" Body lift all around
295/65/18 Duratrac tires
ducati.jpg~original
6c58f133-ef4f-b8e2.jpg~original
No, its an Aura grill. Had it for a few years before the satoshi mod craze. A bit pricey, I'll admit... but I haven't seen any other one in person or on the board yet so I guess it was worth it, I suppose haha.
There are a few other Aura's floating around out there. :D And yes, worth it IMO.:thumb3:
692A0721.jpg~original
NVBASSJUNKIE
