Lift and Tire Central (pics)... Post 'em Up!
Spotted this in my area:
(Not my taste but it could suit someone's needs)
04 4runner blacked out on 22's
Posting these here for when the CL post goes down:
Wouldn't look to bad if it was dropped !
A few inches front and rear. Not sure exact measurement, bought it lifted. Gonna do more digging into this 4Runner and mod it out soon ;)
Finally posting something up here. Before and after installing a 2.5/1.5 Daystar Lift Kit, & 265/65/18 BFG AT KO's.
Wish I had taken more pictures before the change, but it looks much better now.
08 Limited 4x4
M_Webb_ - This looks great man, love it!
Quick tire question!
im going to be running the FJ coils all the way around with the Daystar 2.5/1.5, how much rubbing will i see with a 265/75R16?
probably a little. I have DS 2.5/1.5 and FJ rears. My front rubbed a lot, i had to move the fender liners forward a bunch and trim the mud flaps. I still rub on something at about half lock, but whatever hopefully the extra little lift from the FJ fronts will help you
i appreciate it zopperman!! thanks for the input
06 4Runner
2.5" front spacer lift 1.5" rear coil and shocks. 285-70-17 pro comp Xtreme A/T.
Ride quality
toytec ultimate
roger brown 1.25 bl
1.25" wheel spacers
285/65/18 nitto terra grappler mt
How does the ride compare to the stock ride with the toyotech ultimate lift, is it more stiff, and do thoes tires rub, I have 32 s on my 4 runner with offset rims and they rub a little
Ride
Moving right along very quickly! Today was a big day. Toytec Ultimate lift, ProComp 7105 17"x8", Goodyear Duratracs 285/70/17.
The billet grill may go away soon. Any takers? Now to go pull the front mudflaps. Rub-a-dub-dub!
How does the Toyotech Ultimate lift ride compared to the stock , is it more stiff. Do you have any trouble with your 285 size tires rubbing?
2004 T4R Limited
Lift Daystar front 2.5, back 1.5, Pro Comp 18 x 9.5 inch rims, Tires Toyo AT II 275/65 r18, 32.1 inches tall.
I've added 255/75/17 Goodyear Wrangler Silent Armours. No rubbing, no issues, 35psi front, 33psi rear is awesome, mpg is up, mpg meter is dead-on, stock rims, no spacers. Tire link in sig.
LOVE THOSE TIRES!!!
Finally!
So after two years of owning this particular 4Runner, I can actually post in the "Lift and Tire Central" thread.
275/65R18 Goodyear Duratrac on a 2.5 Daystar front/1.5ish RAS adjust with Spidertrax.
Mods to make it work:
-push fender liners forward
-remove/trim mudflap
-Spidertrax required to clear UCA (so I was told)
New Set-up
Wanted to add a pic of the new Set-up
Front: FJ Springs (1/4-1/2) Billstein 5100's at 1.75 (1.75) Daystar Budget Boost (2")
Front roughly 4" total
Rear: Toytec Superflex Coils (2") Daystar 1.5" Poly spacers cut down to 1" (1")
Rear roughly 3" total
Front is at 37.75"
Rear is at 38.75"
Alignment was in spec with stock UCA's. With barely any wiggle room. I know it will ride better with new UCA's and eventually i will get them.
Tires are Falken Rocky Mountain 265/70. Not the biggest fan of these, all sipping is gone, but lots of inside tread left. Hopefully by tax time or so I will get some 285's. With a baby almost here I don't need to buy tires right now.
Little Moab
Just did a little wheeling at a place near here called Little Moab, they say its where people go to test their rigs before they get to the real Moab. Got some fun pics...
New wheels same bad ass lift!
Just got the new Nitto Trail Grapplers on my 2005 4runner sport! 295/70r18, old man emu + bilstein coilovers , chromoly upper control arms , uniball joints , energy suspension , all pro off-road sway bar links, ect ect ect . I think they look pretty tough , what do you guys think?
Tire issues
Just converted from the Cornfed 1" Front Leveling Kit with stock Limited tires (265/60/18) to the Cornfed 3/2 Lift. Spidertrax wheel spacers, Michelin LTX A/T2 275/65/18 with XREAS preserved. There was no rubbing with these tires until I got the front end aligned. Now I've got a slight rub at the rear of the tire on the frame when cranked all the way. This weekend I'm going to try to adjust the camber a bit to move the wheel forward just a bit. If that works I'll be in heaven as I love the way it looks and drives. If that doesn't work, I am not sure what I will do. I cannot live with the tires rubbing since my son and I do some light offroading.
IMG_1931.jpg~original
IMG_1932.jpg~original
I have a 07 4-runner that just had a Readylift Leveling kit (2.250") added to the front only. I'm running the stock 265/60/18 on it now, but would like to step up to the next size without modifications needing to be made to the mud guards or fender wells. Are there any suggestions? Thanks in advance!!!
utkrstam
