NorthernRyan
I have been attempting to install the OW 2.0 kit for 8 days now. To be fair 5 of those days I had to go back to work but I have been stopping by each night to soak it in penetrant (PB Blaster and will be trying Liquid Wrench Super Penetrant) and hit it a few times.
On the right side I have this:
<a href="http://s1183.photobucket.com/albums/x477/engryan/car/?action=view¤t=IMGP0178.jpg" target="_blank"><img src="http://i1183.photobucket.com/albums/x477/engryan/car/IMGP0178.jpg" border="0" alt="Ball joint taper stuck"></a>
The ball joint taper of the UCA will not release from the spindle even with a pickle fork and big green (8lb sledge hammer). I have put penetrant into the taper, pickle forked, side tapped and even loaded it by prying up the UCA with the LCA attached loading the ball joint and tapping the side of the spindle, to no avail. I will be getting a proper puller with a clamp and screw so I will be trying that Tuesday. I also bought a map gas torch so should I be heating the spindle or the bolt, and how careful should I be?
On the left side I have this:
<a href="http://s1183.photobucket.com/albums/x477/engryan/car/?action=view¤t=IMGP0176.jpg" target="_blank"><img src="http://i1183.photobucket.com/albums/x477/engryan/car/IMGP0176.jpg" border="0" alt="Shock stuck in mount"></a>
The ball joint popped no problem but the top of the strut/shock won't come out of the top frame mount. It has now been 4 days of soaking in PB Blaster and beating down on the spring with the sledge hammer (you can kinda see the green paint on the spring) and I also have been prying down putting a large metal bar through the middle of the spring to a hole in the frame. I'm getting to my wits end on this one. If I heat the top with my new found torch what do i have to be careful of? The fluid area of the shock is at the bottom so would it just be watch out for the abs and brake lines that go across the top? What can I start grinding away? If grind the contact of the shock and frame mount will I risk the spring flying off at some point?
Sorry for the long post but my 4runner is kicking my butt at the moment with around 22 hours of time spent in the garage now:whipping2. To top it off I am using my buddies garage since I don't have one and I think his wife is less than impressed since it's -15 Celcius out and their truck is outside...
I've done my searching on here and have tried all the tips I could find with the side tapping of the joint and loading the joint and even what penetrant to get but I'm still stuck.
So any tips, suggestions or advice would be appreciated guys, thanks.
