rivertrek said:I like the view of the shots you posted already, but they're a little hard to see the tire and spacing detail since they are kind of dark.
If you could please post some full daylight pictures that would be sweet!! Thanks!
smokingun said:I noticed you lifted an XREAS suspension. I assume you used spacers to do the lift. Did you lose any ride quality and handling capability in trade for the lift?
schneidermj said:With 3" spacer lift in the front, nothing else is needed. However if you're doing 2" or more in the back you'll need longer traveling shocks and brakeline extensions. If you ever get into a situation where you get some good flex on the rear suspension, you could be looking at damaged shocks and/or stretched or broken brake lines.
I have the Revtek kit and after doing the install it was obvious to me that these items were needed. I go wheeling a lot and get enough flex on the rear suspension to stack another tire in the wheel well. If you plan on doing any wheeling at all I would highly advise longer shocks and brakeline extension.
rivertrek said:Why is this the first I've heard or read about this :eek2: ???
All the catalogs say that no replacement parts are required? Same with elsewhere on this forum. Now I feel a little scared of the lift, and will have to spend more money, because I don't need to be out in the middle of no where 4wheelin' and have something break. great!!! Now I don't know what to think.
