lift kits
MSU4Runner
I was wondering if anyone knew anything about the Revtek 3" suspension lift kit or the Daystar 2.5" suspension lift kit that they sell at Performance Products. Any opinions? I'm just looking to lift a little for a more aggressive look, I'm not much of an off-roader, other than camping trips, etc.
Also, one more accessory question. Are those little Helix Power Towers worth the $80? There is another company that makes the same thing, but a nice anodized red color, Poweraid Throttle Body Spacer.
If you're looking into spacers I would recommend these instead:
Cornfed Suspension - www.cornfedsuspension.com
They come highly recommended by alot of the toyota community (TTORA) as well as other yota groups. Give them a line!
As for the tb spacer and what not, don't bother wasting your time there. If you want real hp, get a SC or atleast get an exhaust and headers to start. Then work up to the deckplate mod (search).
Good luck!
Thanks for the info. If I went with the 2" spacers up front, should I go for 2.5" in the rear to get rid of the sagging tendencies of 4runners or just stick with 2" in the rear as well?
I was thinking of picking up a set of those Cornfed spacers myself. Are they relatively easy to install?
easy. You just need a spring compressor and you're set :)
You can get em rented free at autozone.
cornfed
How much is the ride affected? My stock suspension setup is pretty bumpy now, but I don't mind. Eventually I would like to uprade my suspension. OME and Bilstein seem to be the most popular.
the spacers will make ya abit stiffer.
Keep in mind that spacers are the cheap route of getting the lift. Going w/ OME's or anything else will be much more expensive.
Also don't forget that you're driving a truck so the ride will be harsh. It's a truck :) If you're looking for a soft ride, lifting will not be a good idea.
I installed
OME 881 up front
OME 891 out back
OME HD Struts Front (Not sure part number)
OME HD Shocks Back (Not sure part number)
Total noticeable lift eyesight. About 1 or more inch up front and at least 2" at the back.
Look at my pics to see how much "damage" I do with the mild lifted .o2 4Runner, with stock tires.
http://photos.yahoo.com/mpampo
See : Lonesome Lake and Evan's Creek Pictures.
