Lift & Leveling kit Holiday Season Sale!
The PO on my rig installed OME suspension and it's sitting on stock rims. so obviously there's already a lift to it compared to factory, and the slump isn't really there. However I still have some of that stupid driver side lean (and you can never have too much lift right?)... what setup would you recommend?
Oh, I should have mentioned this before. These kits have the driver side rear spacer made thicker so after installed, the driver side lean is FIXED! IF you're keeping the rest of your existing setup, I could probably just make you one small spacer for the lean to get you level. Shoot me a text or call me at 717-319-2100
4th gen lift & leveling kits at Burtman Industries - Kits still on sale
Hey Jason, curious about these as I don't know much about lifts. If I get a 2/1 or 3/2 spacer set for an 06 4Runner - will anything need to be replaced? (Shocks, springs, etc). Or is it a spacer that is just a plug and play type fit?
NO! :) That's the beauty of these kits. Everything works with factory suspension, (springs/shocks, and even with Xreas) no worries.
Also, we make the driver side rear spacer slightly bigger to fix the notorious driver side lean that these trucks have (due to the battery and gas tank being on the drivers side) This means your truck will be more level in the rear, side to side, etc. than it is now, after this is installed.
Just got them installed. Working great. Tires look small now.
2/1 leveling kit came out awesome. It sits perfect and alignment even stayed the same.
[MENTION=165600]monk96t[/MENTION] Youre truck sits perfect! Thats how I want to get mine to end up looking. What size tires do you have there? Also, what shocks and springs do you have?
