Lift on the Way
some advice
I'm about to install OME lift this weekend. Dsams you mentioned being careful about the rear tire sensor -- I assume you mean the ABS sensor wire. Can someone who has done a lift be more specific about what one can do to not damage it?
do not over extend the wire. (stretch) when i had my OME suspension done there was no problem. you should be fine.
you are in for some good times with your new suspension. enjoy!!
dan
PaulSula said:
Took it to the dealer down the road and turned a few heads. Had to find another 4Runner to compare side to side with. This picture really doesn't do it justice.
I can tell :) You are on the right side...
2003-2006 Lift kit
Hey thanks... I still am very happy with the lift. Thanks Jason. I have done a lot since then, check it out.
