Lift options for a broke 16 year old :)
Bassman98yota
Hey y'all I'm new here and I have a 1998 with 265/75/16's stock and I dont do too much offloading. I'm looking to lift it about 3inches and I don't need anything really tough. I work and am in high school but I love my car. If y'all have any suggestions about a lift for under 500-600 bucks it will be much appreciated. Thanks!!!!
LOL I know I'm just jokin with ya. I've read too many "free lift, take off your running boards". Sorry that wasn't contributing much...
You can put together a nice little lift for under $600. I pieced mine together for $500. Just do your research, find a couple used springs and shocks. LC springs for $50-80, some rear shocks, used OME fronts, or tundra fronts and you're good to go.
Thanks y'all! I will def look into that. I like the 3 in toytec front spacers and springs but I don't know if that will give me 3in all the way around. I need to talk to somebody whose done it. I'll keep looking.
Ditch the spacer idea, you don't want spacers. Do a little bit of research on this sticky: http://www.toyota-4runner.org/3rd-gen-t4rs/66976-3rd-gen-4runner-lift-information-faqs.html
A great resource.
You can find the LC/tundra setup for very cheap. I would go that route. You might even end up paying less with the front tundra setup than buying new 3" spacers.....
I don't see why you couldn't run a 3" ToyTec spacer up front and go over to Ih8mud and get a set of LC coils for around $60. If you are not doing anything serious then it's a decent first step that will give you a lot of potential for upgrades while on a budget. When the time comes you won't have trouble selling the spacers.
My first setup with a 3" spacer front and LC 8 wrap rear.
True, I'm just saying for the same price as the spacers he could get better coils and better shocks than the ones that are on there now, assuming he's got a stock setup on his truck.
True, I just wanted to give another option for him. Either way I'm sure it will look good. There's a lot of ways to the approach he wants but personally reading builds and deciding for himself what works is his best bet.
I am actually going to be doing spacers after the new year on my runner. I'm not going to be doing any wheeling as I have a 2wd sport edition as I see you won't either... I don't have much to add to your question other than if you go above 2" you will need a diff dropper for your front diff.
Option 1:
A 3inch lift (that you want) with new coils (required in the rear) will get you about $380ish + dollars from toytec.
3" Lift Kit with front and rear OME coils - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
New shocks (rear are required) Cheapest I have found are 99 bucks so far:
Rear Gas Charged Shocks (90-02 4Runner) - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
Extended rear brake line:
$40ish price range
Extended Rear Brake Line - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
Front diff drop:
$30ish
Front Differential Drop Kit - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
TOTAL
$550 without shipping, or tools. This seems doable, but if you add up shipping cost, and maybe if you don't have tools there may be other options for you.
NEXT:
Option 2 (cheaper more money for different mods)
My personal plans:
2.5" Spacers all around $160ish +
Daystar Comfort Ride Polyurethane Coil Spacer Lifts KT09106BK - SummitRacing.com
New rear shocks $41+ish a piece (I believe these are the same shocks as the ones above. But they are for lifted runners, so they should give me more slack for the joints)
Pro Comp ES9000 Shocks 921513 - SummitRacing.com
$40ish price range
Total:
$282ish+
After all is said and done I will be getting:
Shocks up front $61ish (Yea Yea Yea cross branding, if KYB had rear shocks for my plans I would have gone that route)
2002 TOYOTA 4RUNNER KYB MonoMax Gas Shocks and Struts 564002 - SummitRacing.com
Total $404+ish
ADD ON SINCE I HAVE 2WD You will need to add the Front DIFF drop:
$30ish+ so
Total:
$434+ish without cost of shipping.
Disclaimer with my set up, if you have rear sag, and do this you will still have rear sag unless you will be doing this with new rear coils or with airlift.
After all is said and done if you have the money to go a better route than spacers I say go for it. I am going the spacer route myself, I am sure I can go the first route, but I am spacing out my build. ( I am 17 also working on a classic vehicle so I can't just pay attention to my runner)
Depending on how much you know about cars or any help you have you may or may not need to have to pay someone else to do this. If you don't know how or are not willing to learn how, you make need a different hobby ;)
Also, if you are the only one paying for maintenance make sure your maintenance is up to keep before you do any of this!!! A stock 4runner that drives will get you farther than a lifted runner that doesn't go anywhere.
Sorry I haven't been on here in a while but I do have procomp 9000's on the rear right now. Im gonna look up LC coils right now. What kind of coils do I need for the front?
I was in your boat a little while ago. Currently 17 with a job. But the cheapest lift you can get are spacers. But personally I would spend the extra money and just go with brand new shocks and springs. Gonna cost around anywhere from $300-$800 for a full lift. Sorry bud!
leolediola
