Lift pictures!
Wow man looks REALLY good!! I would have to guess it is the tires that are making the ride so rough. A 10 ply tire is kind of overkill for the 4runner. I see you are in North GA. I am in Nashville and come down to Chattanooga some. I need to check out some good hiking and off road trails down that way! I heard there are quite a few in North GA.
You have the 885 front OME springs AND you used the top plate spacer? How much lift did you gain? Also did you change the shocks too?
It's common, it's a 1/4 spacer that nets you a half inch lift in the front for a full 3" lift. Got it on mine too. Checkout toyteclifts.com, it's listed with the OME stuff.
from what I read I know its common to run the top plate spacer on the OME 884 but the 885 are taller to begin with. Thats why I was asking if he had 885 and the spacer. I posted a tread yesterday and the couple people that answered said skip the spacer on the 885's if you are all stock weight.
Not taller, they are stiffer. He does have the spacer, as do I.
I called toytec and the 884 and 885 are the same spring rate. They said 885's are a little taller
What do I know right? I only installed them on my truck 6 months ago......
Are you putting them on a v6 or v8? Are you adding any weight later?
im just south of ya in murfreesboro... no too many trails to check out unless you just like gravel roads
Just like zstampe said.. Med spring and 1/4 spacer. I was told by ome that the med weight was "not recommend" unless I was going to put on after market bumpers. I went ahead and did it because I needed all the clearance I could get for those tires.
[/QUOTE]
Those were my 2nd choice of wheels. They look great. If I couldn't find the right tire for the 18's, I was going to buy a used set of those.
ok cool. I just ordered the 1/4" top plate spacers so I can have it all done at once. I am doing the exact same thing just 265/70/18 on 18" limited wheels. What shocks are you running?
The ome nitro ones. I've got 275/70/18 not 265. I couldn't find 265. What company makes that size? It's a TON of cutting. I'll shoot some pictures
You'll be happy for sure man. No such thing as too much lift! Ha ha.
I'm running bilsteins
well hopefully my smaller tire size and less aggressive highway tire will yeild me less cutting. Your 4runner looks awesome!
agreed as long as cv boots stay put!
yellowssm;891497 agreed as long as cv boots stay put![/QUOTE said:
Ha! The cv boots won't! It'll be fine though. I took some metal bands and re did mine, haven't leaked since.
That's Exactly what I used. I went to the local hardware store and got some and put them on while getting paid at work ha ha.
