Lift Questions
BlackYotaSport3
I currently have the "Best Seller" 3" Kit w/front spacers and rear coils and it rides really well. I have 275/55/20 inch nitto terra grappler tires and i want to put on the nitto trail grapplers which will be 295/55/20 (32.90 inches tall and 12.5 wide) but they will rub.Is there any other lift that i can add on to my 4runner that will allow me to add these tires without rubbing? thanks
No there is no lift you can run those tires without rubbing unless you do some trimming. Is it a spacer lift that ou have? If so then you will have to chop the body mount too. How much are you getting those trail grapplers for? I am debating on those when I move to 35's. Oh one more thing, if you went to a coilover suspension then that paired with a 1.5" Body lift would be able to clear those 33s I'm pretty sure. Maybe minor trimming.
ok thanks for the information...i have front spacers and real coils..could i add anything to that? im looking at about 1300 for the four trail grappler tires
i just got off the phone with toytec and he said i can add the 1" body lift. Does anyone have this added onto their other lift?will it be rougher?Will it add clearance to put bigger tires on? thank you
Yea it will add clearance but you can get a 1.5" Bidy Lift from 4crawler body lifts. I would definitely go ahead and do the 1.5" if you don't want to trim very much.
BillM777
