lift ???
cruzsrf
got a 98 4runner w/3in. spacer lift in front w 1in diff drop/lc coils rear problem is cv angle keeps tearing cv boot's gone through 2 new ones already.Question is by changing out the front spacer lift and replacing it with the toytec adjustable coilover would that help better my cv angle along with the 1in. diff drop.
thank's
and if anyone has pic's w/the same setup in front can u please post up pic's
Yes, you'll want to bring down the front a little bit. If you're hard up for cash, just buy some smaller spacers. You can get some old man emu 881, 882, 883 as well. They all add different heights so read up on that. Toytec adjustables are good for the money as well and you can tune in your ride easily.
got a 98 4runner w/3in. Spacer lift in front w 1in diff drop/lc coils rear problem is cv angle keeps tearing cv boot's gone through 2 new ones already.question is by changing out the front spacer lift and replacing it with the toytec adjustable coilover would that help better my cv angle along with the 1in. Diff drop.
Thank's
Ya planning on grabbing the toytec adjustable coilover but just wanted to see if i set it at 3 1/2 would the cv angle be the same
Thanks again for the replys and help
If you have the coil overs set for 3" lift like your spacers than the angle will be the same. If you drop it down too 2.5" you will lower the angle. Research cv boots and you will find its a common issue and there are ways to upgrade or stop them from ripping. You dont want too run 3.5" suspension lift on the front, it will make the angles even worse.
Ok thanks for the help so i might just get a full 4 in lift w/ crossmember drop
Thanks again and any recomended lift
Also my runner is just a daily driver no wheeling
BillM777
