Lift?
I want to get 275/70/17 BGF A/T's on my t4r. What lift should i get to make this fit/ look the best?
I put the 2.5/1.5 and 265/70 I like the way it looks.. I think either the 2.5 kit or the 3/2 kit would look good. All based on personal preference though good luck with your decision man!
I have those exact tires...I have daystar 2.5/1.5. They fit nicely. I did trim the plastic up front and remove mud flaps. However, I'm also adding my spidertrax this weekend....got them in the mail yesterday, itchin to put them on. I have a picture in the lifts section and pics section in the sticky up top
I'm selling my spacer lift that comes fully assembled which I ran with 275s.
045.jpg~original
PM me if interested
Some members did baby steps by going w/ a Spacer Lift & many members Did It Right The First Time.
I currently still have my Daystar Spacer Lift...after 2 month, I was ready to upgrade. I haven't upgraded yet, because the wallet won't let me!!
Anywho...I was reading about Daystar Spacer Lift for over a year if not two. I landed a Used Daystar Spacer Lift Kit & was hyped up to install them. If you don't know how to do suspension, you'll easily spend $300 on labor alone. Good thing I have a friend w/ a shop, I was able to help w/ my supervision as a peace of mind. My goodness...all that work just for a slight increase. If I did it all over again...I would go straight to Coilovers.
I have the Daystar Spacer Lift & I was drooling over it for a year till I finally caved in.
It definately looks nice, but it's the same travel as stock, because you're just adding a spacer to extend the stock strut/shock assembly.
I actually help do the install & it's so much work for so little improvement.
I don't regret doing it, because if I didn't do it, I wouldn't have known this information.
If I did it all over again, I'd go with...
• OME
or
• Overland Warehouse Radflo 2.5
I didn't replace my UCA, because I stuck only stepped up to 32" tires, if you were to step up to 33" or higher, then you need them for clearance.
As for alignment...only the Toe Angle for the front are adjustable, and my Caster Angle wasn't out of whacked too much, my vehicle is traveling perfectly straight.
If you need photos or have questions about the Daystar Spacer Lift...please let me know. Actually if you need a Tutorial in installing a lift, let me know.
Post #2
http://www.toyota-4runner.org/772392-post2.html
Post #6
http://www.toyota-4runner.org/772656-post6.html
Post #9
http://www.toyota-4runner.org/774714-post9.html
Full Thread
http://www.toyota-4runner.org/4th-gen-t4rs/88736-daystar-lift-questions-opinions.html
If I was able to remove the Spacer in a blink of a second from a Magic Genie...I'd let you have it.
...Please don't hesitate if you have more questions...
Husker's kit looks like the best way to go. If you want a spacer lift I highly recommend the 3/2 Cornfed kit.
okay so the OME lift is what i think looks best for the money and performance. I think i'll do that one. good idea?
