Light wiring and switch question
VonMussa
I have two sets of Hella Black Magics on a Defiant bar. Is it possible to wire them together to use one swtich? Apologies if this is rudamentary but I have no experience with this and have used the search function and google without much luck.
Also, does anyone know which OTRATTW color looks best with the limited interior lighting? I may just get a green/red Contura V switch.
Yeah it's very easy, it's safest to use a relay though. Just have the lights powered from the relay then your switch only holds enough power to close the circuit.
As long as the lights are 55W, as I think they are, a 20A relay will be fine. If they're 100W you'll wanna use a 40A relay or one 20A to each pair with a single wire coming from the switch then split to go to both relays.
This thread has a pretty good summary of how to use the relay in case you don't know - DIY: Wiring after-market lights - Tacoma World Forums.
Can't help with the color though.
Yes very possible, just need to wire up both relays to be triggered by a single switch that's all. I am assuming each set of lamps would have it's own wiring harness and relay?
Not sure about the switch colors though :)
A relay isn't needed, it just gives you another point of failure.
A fuse is required for any add-on wiring.
OTRATTW switches are rated @ 20 amps, a pair of 55 watt lights will draw just under 8 amps, even a pair of 100 watt lights will draw just under 15 amps so you don't need a relay. For a 8 amp draw, I would use a 10 amp fuse as close to the power source as possible. 18ga automotive grade wire will work nicely for this application.
For the switch, I like red for the back-lighting, the ON indicator color is up to you,
I'm using orange switches in my Limited and they match nicely with the OEM switches.
More details, part list, pics and wiring diagrams here: http://www.toyota-4runner.org/5th-gen-t4rs/94578-okkis-build-thread.html#post831769
Okki
bluelinepilot
