Limited 20” wheels
coho51
Guys, a few weeks ago I picked up a 2011 Limited. It has 20” wheels so I was wondering if there was any problem down sizing to 17” rims and wheels? Also I really like the newer model front clips with round running lights can you change the out with newer? Thanks for helping a newbie.
Downsize at will. The smallest you can go is 17". Anything smaller will not clear the brake calipers. Front clips will likely require a significant investment to make work. The headlight change on the 14+ models had a significant impact on the entire front end.
Forgot to say that you should research the specific wheels you want, as well as the tires to make sure that the backspacing will fit without rubbing.
If you can pick up Trail or Off Road wheels from someone upgrading, these are great wheels at cheap prices that you know will fit.
http://www.toyota-4runner.org/2968741-post454.html
Jhunt
