Looking at a '03 V8..
did you check the spare tire ? I had the same issue, but have since got bigger tire and had the TPMS taked out, and did the TPMS mod :thumb3:
No I didn't check the spare. Doh! My bad. So there is a TPMS mod?
So I ended up buying the one pictured above. Right off the bat I'm fighting a small issue. The rear license plate bracket appears to be gone. All that's there is two rusty holes in the sheetmetal. That's it. Surely something is missing to attach the license plate to, right? I can't find any screws to thread into the sheetmetal so I assume something is missing.
thats kinda weird lol, there should be nuts spot welded on the inside of the sheet metal for machine thread bolts to screw into. you may be able to find a small toggle nut bolt that can fit into the exiting hole and work for you.
utkrstam
