Looking at a 1998 Toyota 4Runner 2.7L 4 cylinder Auto 4wd loaded
yotaME
Going to check out a 1998 4Runner looks to be in nice shape. This would be my primary driver. Has a 2.7 L 4 cylinder. I use to have a 2002 Tacoma and loved it.
I do tow a 6x10 trailer with a garden tractor on it. Should I have any concerns overall ?
Here is the ad:
1998 Toyota 4Runner
2.7L 4 cylinder giving you 20+ mpg
129,xxx current mileage
Auto 4 speed
4wd
Dual Airbags
Power windows
Power locks
Power moon roof
Roof rack
Power rear window
Trailer hitch 3500# max capacity
Floor mats
New leather wrapped steering wheel
AC blows cold
Cruise control
Heat blows hot
Single factory CD player
Sticker runs out in October, will take another no problem
Full size spare
Tires and wheels in excellent shape
EVERYTHING WORKS AS IT SHOULD! except the power radio antenna, simply use it manually (works fine)
It took me many months to find this clean example, frame is good, very minor surface rust, good bumpers
No dummy lights, gas and go!
Title in hand
No trades
Cash only
This 2.7 4 Cylinder is a chain driven engine (no timing belt to break)
All fluids topped off
Engine oil clean
Recent Maintenance (in the last 1000 miles)
Two rear brake lines (the ones above the fuel tank) replaced $500
All engine belts (3) with high quality 3 year warranty replacements $125
Cat back exhaust, all new with 30 miles $300
Rear drum brake service and ebrake adjustment $100
This truck is ready to take you 200k plus easily, with AC in the summer and grippy tires and 4wd in the winter and an economical 4 cylinder saving you on gas all the time!
I would verify VIN/ mileage, and have a mechanic check it out if you're not comfortable doing it yourself or don't know what to look for.
Other than that, it looks pretty clean. If all checks out, I would buy it. GL!
$5,100.00
So towing a 900 pound garden tractor would be ok?
I have a 2000 with a 2.7 auto. I do tow with it, but believe me, it's not easy. I generally tow less than 1000lbs and it kills any semblance of fuel economy or normal driving. Want to pass that car? Forget about it.
I have towed bigger loads a few times, not fun either but it will get you there. I generally switch to my LC for the heavier stuff. The bigger challenge is brakes, I've warped two sets of rotors in 10K miles. I'm shopping for 16" wheels so I can get tires. Then I'll do the Tundra brake upgrade. So I guess you just need to understand the limitations. If you towed everyday, I'd say this isn't the ideal truck for you. Otherwise, you decide.
$5,100.00
Very good price, I think anyway. Yeah I'm sure it can handle 900 + the trailer weight, probably another 600-900lbs. Like any other towing, take off slow and ez and brake well ahead of time. :^)
