Looking to get a 97 4runner, what should i look for?
deckert4r
I am looking at a 97 4runner sr5 w/ 135k miles. Its a 5 speed manual, 4x4, leather, sunroof. He wants 8900.
Whats normal and whats a good deal?
I am wondering besides price, what should i look for? Any warning signs should i look for? Any 4runner specific problems i should know about?
Thanks Everybody,
Ben Decker
I just bought a '97 SR5 for $7,200. It has 140K, 4WD, with only minor interior imperfections. I had to travel about 700 miles for the deal, but I was headed that way anyways. A comparable vehicle in Iowa and Chicago area was running about 10K.
depends on your location, each one 4Runner will have specific perks to it.
I got mine exactly same setup as yours with the V6 and 150k for 8.
check to see when was the last time he did any for of maintenance on it. and just take it for a test drive and see how you like it personally.
Ask him for timing belt records (although the 4R is the type of engine that will not break if the belt does..forget what its called again...interdependent maybe?). I would also ask for all the maitenance records...lets you see how the car has been treated. And if you can, I'd take it to a mechanic...most of them will do quick used car inspections for around $70-100..seems like a lot but it can really pay off in the long run...
druuu88 said:
Ask him for timing belt records (although the 4R is the type of engine that will not break if the belt does..forget what its called again...interdependent maybe?)...........
Interference.
Like any used car/truck look for the tell-tale signs of abuse.
Check the underbody for rust
the oilpan shouldnt have any dents
rear tailgate window goes down smoothly - and back up when you want it too.
check the 4x4 Hi/Lo and 2x4 that they are working properly and not stuck in mode.
check under the rear seats and make sure the jack and spare tire arm is still there.
ask for any receipts for any work done to the car (recent tuneups, timing belt, waterpump, etc)
If he lets you - jack up the car to inspect the floors for rust, holes, dents. While it's up - try to shake the front wheels - if there is any play, then you may have some suspension work to get done.
OR, an alternative is to find any abnormal tire wear in the fronts.
also - try to stall him for as long as you can before he starts the motor. If a cloud of smoke explodes out of the exhaust when you start it up...it could be that the valve stem seals are gone - which is $$$$$$
Find everything that is wrong with the truck - and I mean ANYTHING that you can use to lower the price. paint scratches, stone chips, dirty carpets, muffler too loud, no cigarette lighter....whatever. Parts are hard to come by (in my area anyway) because the 3rd gen Runnners NEVA DIE!!!!! I cant find any parts at any scrap yard, used parts stores, or auto recycler.
peacefulpiranha
