Loud groaning when turned to full right**
DirtySouth89
My 06 SE has been doing this thing ever since I bought it. When turning the wheel to its full stops right* only, not left, and then inching forward at slow speeds, something down in the chassis area groans loudly. The 4R is all stock and all proper sizes.
Edit: I can't believe I had that wrong but I edited to remove that this happens when turned left or right. *It's only when turned right.
so the groaning happens only after you go full lock and then inch forward? The process itself of going to full lock doesn't produce the sound?
Correct. Turning the wheel far right** in-place does not produce any noise. Only when it begins to inch forward.
Without knowing all the details and not being there I am going to guess you have a bad wheel bearing.
Jack the front wheels up one at a time and rock the tire up and down with your hands on top and bottom of your tire. You should not have any play. If there is play you have a bearing going out.
another possibly important variable
My whole 4R chassis is surface rusty. Like every part that exists, evenly coated in rust down there.
I had the passenger side WB fail at 100,000 miles. Made a groaning sound.
Had a professional shop with great mechanic knock out the bearing.
Next time I would replace the whole assembly with a bearing and save 3 hours of labor. Amazon.com: DTA Front Wheel Hub Bearing Full Assembly NT5150402WG3 Compatible with Front Left or Right Toyota 4Runner Tacoma FJ Cruiser Hilux 2WD Only, Will NOT Fit 4WD. Replaces Dorman # 950-004: Automotive
1 year or 12,000 miles limited warranty
I have a spare WB assembly from Amazon for when the driver's side WB fails. I'm now at 150,000 miles.
WB's fail. Nothing else you can do but fix it.
delislerebecca
