Louisiana Overland - Build and Adventure
What brand of snorkel did you use and did you have to adjust anything to use a precleaner vs standard scoop? Where did you get the precleaner?
Thanks and safe travels.
I ordered through Mammoth4runner on instagram. The snorkel is from 4wdadventures and the prefilter is from snorkel upgrade. Mammoth had it all listed in his store with discounts at the time. The prefilter requires a rubber adapter bushing that was ordered together with the rest of it.
Love the tank mount. Can you give us details on what mount did you use and how did you mount it? Thanks!
Its an 11lb tank. 2.5 gallons. Its the same height as a standard tank but only 9” diameter. It is mounted to a powertank bracket that they make for the tank. I brought the tank, the bracket, and a 2” receiver blank to my local fabricator(SSO) and they mated it all together. I use an anti rattle hitch pin to keep it all tight in the swing out. Easy-peasy. It wasnt an inexpensive project though. I just refilled the tank. I had cooked on the stove a dozen times and ran a buddy heater several hours. It took 1/2 gallon to top it off. No more little green bottles.
realjeffedup
